Results 1 to 2 of 2
Thread: Weird problem-ABS & Traction assist lights
    Greetings,
    Anyone ever run across this problem? When I start up, shift into drive and take off, my traction assist "off" button AND the ABS indicator light on the dash both light up simultaneously. Is there a connection between these two indicators? So last night on the way home from work, I picked up a code reader from O'Reilly's. Haven't had a chance to check it out yet, so I don't know if it'll throw a code or not. Everything works fine, no braking problems or anything.
    This winter I plan to completely redo the suspension. Konis, all polyurthane bushings, new subframe bushings, the MN-12 subframe strengthening job (added welding, plus either paint or powder coat), new front suspension pieces too.
    Don Klitzke
    Prospect, TN
    New Lenox, IL
    819
    One of your rear ABS sensors has a problem. The T/C and ABS both use the rear ABS sensors to function. The sensors are right on the rear pumpkin where the halfshafts exit if you want to take a look.
  2. ok guys got a weird problem
    By chris94SCmt in forum Technical Forum
    Last Post: 09-06-2002, 08:29 PM
  3. ABS / Brake Problem
    By 93scto in forum Technical Forum
    Last Post: 07-02-2002, 09:27 AM
  4. ABS Brake Problem
    By Mitch90BlackSC in forum Technical Forum
    Last Post: 06-27-2002, 06:26 AM
