Results 1 to 15 of 22
Thread: 95 5-speed running like crap...
    Michigan!
    775
    Alright heres the scoop guys, the car idles perfectly at a stop without a miss or anything. But when I go for a take off (just normal or hard) the tach falls slightly like it is going to stall. The car hesitates and then comes back to life.
    Another example, if I tap on the gas consecutivley and say keep it around 1500 rpm. making sure im taping the gas like blipping the throttle, it will pick up like normal sometimes, and other times the tach falls back down to about 1200-1300 like someone stopped the airflow on the engine.
    Also while I am driving and apply the gas it also hesistates but once it starts moving it seems to be ok. A guy at the local ford shop ran a diagonostic on it and said that the computer wasn't "reading the MAF sensor" and I have tried running the car with and w/o the MAF sensor plugged in and it also runs like crap with it unplugged. So my question is, do you think it is an accurate diagonsis of the problem and should I replace the MAF sensor itself? Because it does run differently when its plugged in so I woulda thought it would be reading it. It is a C & L Maf sensor with a yellow sampling tube i beleive to be right with my 36 lb injectors. I just dont' know what else to make of it. My next question is if I FIND out that this is my problem the sensor has to be out of a late model SC correct? What are other possibilities that it could be?
    The HG's were just done on the car and the car was sealed back up perfectly. It did it before the HG's and it is also doing it after.
    Jul 2004
    Toledo, Ohio
    513
    Hey 91BLOWNSC.
    It sounds like the MAF sensor is bad. You could check the EEC youself to see if it is listing a MAF code with a hand held scanner. Or use a voltmeter on the diagnostic plug to read the pulses generated by the EEC. Auto Zone I believe will scan your car for free if you want a second opinion. Looking at the code chart, if the MAF sensor is bad then you should get one or more of the following codes;
    26 - MAF Sensor out of range
    56 - MAF Sensor out of range (high)
    66 - MAF sensor circuit out of range (low)
    or (most likely)
    157 - MAF sensor below minimum voltage
    158 - MAF sensor above maximum voltage
    159 - MAF sensor out of range
    Another possibility is the throttle position sensor. I have had trouble with my 86 N/A 3.8 Mustang stumbling through accelleration. I had to bench test the TPS and found a dead spot in the cruising speed position.
    The codes will help point in the direction of the problem.
    Hope this helps!
    Michigan!
    775
    Quote Originally Posted by blue94sc
    Hey 91BLOWNSC.
    or (most likely)
    Hope this helps!
    Thanks! I will definitely go have them test it tomorrow or saturday for that matter. Something I forgot to add is the car will stall while I am at idle for a bit. It just starts stuttering and then dies. I may just go to my local murays and scan it myself. But sometimes I don't think Im using it right. Thanks for the codes tho I will write those down.
    I see your located in toledo, im down there often actually. We should meet up sometime! Your ever take your car to milan?
    Aug 2002
    822
    i would say clean your maf wires (the delicate wires inside the sampling tube), and replace your cam sensor. my 5spd behaved very similar to this, and all i did was change the cam sensor, and it now runs perfect. also give some attention to the ignition switch inside the steering column- it seems that high mileage SC's tend to have this problem (happened on both my SC's), the inside of the switch box (upper contacts) was not making full continuity with the bottom contacts- this was causing all sorts of electrical problems with ignition, and brakes.
    Jul 2004
    Toledo, Ohio
    513
    Quote Originally Posted by 91BLOWNSC
    I just bought my 94 this year in late June. I have had to do a little work on her; brakes, front strut bushings, etc..
    She's still stock as of now. I hope to get the exhaust done as soon as I sell my 86 Mustang hooptie. Then it will be the intake mods next.
    I haven't raced her yet. She has 140K miles and the trans shifts hard in 2nd (probably synchros). I plan or replacing the original clutch and rebuild the trans while it's apart.
    Racing would be a real pain with a sticky 2nd gear.
    I hope to make it to an event sometime soon.
    LMK if your going to be in Toileto (ha). I'm right off of 75 and Alexis Rd.
    Later.
    Bill
    Michigan!
    775
    ok.......I pulled the codes.
    Well the codes were 126 BAP sensor out of range, code 157 MAF sensor voltage to low and code 181 and 189 to say that both banks were running lean.
    My next question is, are all the bap sensors from 89-95 the same for our SC"s and interchangable? And where exactly should I get a new MAF sensor...pull it off an SC at the J-yard? And are those interchangable?
    Thanks.
    Nov 2002
    Middle-O-Nowhere, Upstate NY
    627
    maf and bap
    you need a maf for a 94-95 sc as the injectors are larger and the transfer function of the maf is different. the bap sensor i believe is interchangable. i have both for a 94 sc that i can lend you to test before you buy new, or if youre sure thats your problem ill let then go for a low price. good luck, mike
    Michigan!
    775
    That would work!!
    Charkly, that would be awesome. Though, if we could make arrangments on what you think you might like for them if they do work it would be great. I am going to school and on a limited budget, I had a few other things drain me recently so I dont' want to get them all the way over here and not have the money for them. We can talk through e-mail if you'd like. iott17@yahoo.com is my e-mail. Thank you for offering also!!
    Aug 2003
    Cary, North Carolina
    5,075
    Hey blown,
    I think the maf being bad might cause the lean running codes you got. If the maf isn't operating right, it will affect the air/fuel mix and cause a lean or rich condition. Get the maf replaced and should clear up the lean condition. I'd check the codes again though, just to make sure.
    Apr 2004
    48183
    3,935
    hey 91blownsc i live in southeast mich to what city do you live in? i hope to make it to milan sometime soon
    Michigan!
    775
    umm
    I live in the monroe area. you?
    Michigan!
    775
    No luck :(
    Alright guys, Well I tried cleaning my MAF sensor and that didn't work. I have been taking it out every once in a while, including just tonight. It seems to run horrible when I first start it up and always wants to stall. Which wouldn't make sense because is it even usign the MAF sensor at this point in time? Well anyways after it warms up a bit she seems to be ok and idles like a dream. But you give it gas and its almost like the car doesn't want to rev kind hesistates and what not.
    Another sign i seem to have is everytime I go into boost mode the check engine light will come on. Or if I get on it hard. So i pulled it back into the garage and let it idle with the MAF plugged in and it ran like crap and started to stall (which it does if you let it sit to long) and before that happened i unplugged the MAF and the engine ran smooth as silk. Plugged it back in and the engine bogs down again and wants to die.
    Like I and everyone else thought it was the MAF because Like i said when I ran the codes it came up the MAF sensor voltage was to low and the BAP sensor was bad. So I put new ones on the car and it ran the EXACT same way, can someone please explain what they think the problem could be. I am out of ideas. Thanks.
    Michigan!
    775
    Anyone
    Come on, anyone?
    Aug 2003
    5,075
    Come on, anyone?
    It still sounds like it might be the maf to me. If it will run without it plugged in even if it's bad and just die with it plugged in, I would think you need a new one or maybe there is something in the wiring harness. Doug Franklin had a problem like that and it ended up being the maf that was bad. Check with him and see if he can tell you anymore about it.
    Good luck!
    Michigan!
    775
    But I tried one that worked off of another SC. And it ran the same way! Thats whats pi$$ing me off. I am not sure what else to try.
  1. I found this FAQ on the SC
  2. Running Like Crap!?!?!
    By ThunderCoupe94 in forum Technical Forum
    Last Post: 08-28-2003, 01:48 PM
  3. CRAP! I'm in need of a Multi Function Switch CRAP!
    By Ryan A Harris in forum Super Coupe Club of Ontario
    Last Post: 05-21-2003, 01:21 PM
