Results 1 to 5 of 5
Thread: Keyless Entry Pad Problems
    Brampton
    452
    Hi,
    For some reason, a little while ago, the Keyless Entry Pad on my driver's door stopped accepting my entry code to unlock the doors. Funny thing, if I do the entry and then hit the other key to unlock the trunk...that works. So the keypad isn't dead. I've tried disconnecting the battery for a while to reset things...but it still doesn't work. Any ideas?
    Jim.
    Jul 2004
    Salt Lake City, Utah
    1,521
    If your door lock solenoids work when activated from the switches on the door armrests, then it would probably be the module in the trunk on the drivers side fender.
    Brampton
    452
    Does that mean the module is pooched or is just having issues?
    Do you know if there is anyway to reset/fix it?
    Jul 2004
    1,521
    Open it up - it looks really flimsy. A component may have gone bad, or there may be a broken or cold soldered joint.
    The only other thing that I can think of is the wiring or connectors.
    Brampton
    452
    Cool! Perhaps I'll tackle the thing on the weekend. Thanks for the info!
  1. Keyless Entry FOB
    By XR7 in forum Technical Forum
    Last Post: 08-18-2012, 10:58 AM
  2. porblems with keyless and illuminated entry
    By superc0upe in forum Technical Forum
    Last Post: 11-16-2003, 02:32 PM
  3. Damn Keyless entry pad wont light up all the way!
    By syphon in forum Technical Forum
    Last Post: 10-13-2002, 03:00 PM
  4. keyless entry
    By Thunder8289 in forum Technical Forum
    Last Post: 09-18-2002, 12:29 PM
  5. keyless entry
    By Thunder8289 in forum Super Coupe Club of Western Canada
    Last Post: 09-11-2002, 10:50 AM
