Results 1 to 4 of 4
Thread: May have found reason for increased oil consumption
    21,093
    Ever since removing the engine to repair damage from a broken lifter retainer this spring (new cam, lifter, retainers, oil pump, timing cover and dampener) I've noticed that the car is using alot more oil and is even leaking a little on the front and rear main seals.
    Most of the oil has been going into the intake from the PCV valve, and even with the oil seperator I installed, I'm still getting enough in the intake to have oil drip from the IC tubes when I remove them to work on the car.
    When under the car last night installing new o2 sensors, I noticed that the dipstick tube isn't seated into the block properly. It lacks between 3/4" and 1" of being all the way in. So I've been over filling the oil by whatever amount that equals on the dipstick. I'm guessing somewhere between 1-1/2 and 2 quarts.
    I'm not a 100% that reducing the oil level will fix the problem, but I think it's a step in the right direction.
    Madison, Ohio
    17,665
    That would do it. You might even pick up some HP now!
    Email me here.
    Aug 2002
    LONDON ONT. KANaDa
    891
    Murphy's law
    allways something with you MR murphy ...breaking this and that...LOL
    may want to try and install ... some vent filters on the rocker covers to release some of the crank pressure ..had simlar problem on a race car ...though turning constant left would pump the oil up through the rockers and blow the pvc valve right out of the socket... even though it was on the right hand bank...a pair of vents on the left bank fixed it .....dave
    Oct 2003
    Las Cruces, NM
    279
    Quote Originally Posted by MercsSC
    It's Not my fault!!!! Why does every one blame me???
  1. steps to change oil for men and women LOL LOL !!!
    By stephens89sc in forum Non Technical Forum
    Last Post: 12-20-2006, 08:56 PM
  2. Maintenance Schedule?
    By Flip in forum New SC Owner Forum
    Last Post: 08-31-2003, 07:36 PM
  3. High Oil Consumption
    By Mike Farish in forum Technical Forum
    Last Post: 06-30-2003, 12:35 PM
  4. Oil consumption & compression checks
    By xman in forum Technical Forum
    Last Post: 08-13-2002, 02:50 AM
