Thread: Overflowing Brake Fluid Resivore!
    Aug 2004
    Reno, NV
    8
    Does anyone know why a properly filled brake fluid resivore suddenly over flow, while at the same time causing the brakes to feel soft and the ABS light to come on?
    Is there a clog in the system somewhere or what?
    Also, is there a fuse for the turn signals? If not, what would cause them to suddenly stop working?
    Any help would be great, we need to get it fixed by 1:00 today!
    Lakewood, CA
    1,122
    Quote Originally Posted by dr.evil
    Well, overflowing the reservoir is why the brakes are soft and spilling over obviously. I think the fluid level changes quite a bit with applying the brakes too. As far as the turn signals, do they just not work or do they not flash?
    Aug 2004
    Reno, NV
    8
    We got it...I checked all the fuses, and although the turn signal and the ABS fuses looked good, I swaped them with new ones and everything works now.
  2. Brake fluid problem
    By iwannanSC in forum Technical Forum
    Last Post: 11-30-2003, 07:32 AM
  3. ABS and Brake Lights , Low Fluid
    By BossCougar in forum Technical Forum
    Last Post: 08-29-2003, 11:31 PM
  4. Brake Fluid leak from??
    By rab4jc in forum Technical Forum
    Last Post: 04-22-2003, 10:24 AM
