Results 1 to 4 of 4
Thread: Transmission cooler question.
    Mar 2003
    Noble, Ok
    375
    Where is the best place to mount a tranny cooler on a 94-95 SC? In front of the AC COndinser the pusher fan is in the way. Ant idea's?
    Oct 2002
    Peoria, IL USA
    229
    By the oil cooler
    Would it be possiable to place it by the Oil cooler, or on the other by the IC, ?
    Matt
    Joisey Jim Guest
    I guess it depends upon what type of cooler you have or plan to have. I have a simple tubular one about 18" long & its mounted in the front bumper opening with some simple angle brackets I made myself and, bolted to the upper side of the opening. You may want to look and see how much gap there is between the condensor & the rad, because that would be a good place and would also make use of the cooling fan.
    Mar 2004
    Hamptons, NY
    107
    i have a 94 sc. i moved my horn and mounted it on the back side of the bumper, right in front of the air intake on the left side of the license plate.
  1. Transmission Cooler or Shift Kit?
    By 91BLOWNSC in forum Technical Forum
    Last Post: 06-09-2003, 01:22 AM
