Results 1 to 4 of 4
Thread: Help! Can't get slave cylinder line off!!
    Feb 2003
    California
    15
    Unhappy Help! Can't get slave cylinder line off!!
    I think I'm in over my head here... I have my '95 SC in the air to replace the clutch. Everything was going fine until I saw that damn hydraulic clutch line going through the ?bell housing? (at least that's what I think is is, even though it's molded with the tranny) How in gods holy name do I get that thing off?? It looks like it might be an air hose type fitting, but knowing Ford, it couldn't be that easy. I searched this forum and turned up something about a special tool?? (gulp) and I was wondering if anyone has done one of these before, with just a regular shade-tree mechanic's tools. Any help would be greatly appreciated, Thanks.
    Brian
    Surrey, BC
    317
    Its very simple to get off, even with a slotted screw driver.
    Spray the fitting clean with some brake clean and youll notice a white plastic ring around the fitting. Once clean, spray the white ring with some wd-40 for lube, and work the ring in towards the transmission with the screwdriver.
    Feb 2003
    California
    15
    Thanks so much livn, your advice worked like a charm... unfourtunatly, the transmission won't seperate from the engine now. I have removed eight bolts, and I can't find any more but the transmission doesn't budge. I even sprayed penatrating lube into the dowell allignment-shaft things on either side of the "bell housing" where they meet with the tranny. Any Ideas?
    Brian
    birmingham, al
    381
    did you get the 2 at the VERY top of the tranny?? they're a ~~~~ to get, you can't see them from underneath, but they'll stop you from pulling it.
  1. Clutch slave cylinder shim.
    By MartianBob in forum Technical Forum
    Last Post: 11-17-2003, 10:30 PM
  2. Slave cylinder problems
    By RandenSC in forum Technical Forum
    Last Post: 10-13-2003, 02:49 PM
  3. Slave Cylinder Replacement
    By gregucf in forum Technical Forum
    Last Post: 07-08-2002, 06:22 PM
