Results 1 to 8 of 8
Thread: Wondering if these rims will fit on my 92
    Jul 2004
    Cedar Falls, Ia
    56
    I was looking through the Summit catalog and found these rims.....
    American Racing Equipment:
    Estrella Series 95 Wheel
    *Bolt Pattern: 5x5.25
    *Size: 16x7
    The bolt pattern for the stock rims is 5X5.25 right? Also, what is the size of the stock 16'' rims?
    One more thing... Is it possible to get a replacement of the little tool needed to get the rims off? If so where and how much?
    Farmington Hills, Michigan
    124
    No Dude,
    The bolt pattern on all 89-96 Tbirds is 5 on 4.25 in.
    Fast Jimmie
    Jul 2004
    Cedar Falls, Ia
    56
    my fault....
    Bolt patterns for the Estrella Series 95 wheel are:
    4X4.25
    4X4.5
    4X100mm
    5X4.25
    5X4.5
    5X100mm
    5X115mm
    So these will fit...yes?
    If it says 16x7 for the size...then its 7" wide..right? How wide are the stock rims...what is the size 16x?
    Thanks
    Dec 2003
    Altoona IA
    3,237
    Quote Originally Posted by Ia92SUPRCUPE
    4X4.25
    4X4.5
    4X100mm
    5X4.25
    5X4.5
    5X100mm
    5X115mm
    Thanks
    Yes 7" wide.
    But you also need to know the wheel offset...which according to TireRack is 40mm. Can someone else confirm this.
    TX.
    222
    If'n I remember correctly, the correct MN12 offset is 39mm.
    Jun 2004
    Atlanta, GA
    823
    Our bolt pattern is coming up as 5x108, so none of those rims will fit I am figuring?
    Tirerack.com has a good breakdown table of inches to mm.
    Jul 2004
    Lawton, OK
    88
    5x108mm equals 5x4.25. With only a 16" wheel, you can play with the offset a little. I've seen everything from 36mm to 40mm offset before.
    Jun 2004
    Atlanta, GA
    823
    Quote Originally Posted by Rich1034
    Duh, my bad! I read the 5x4.25 as 5x425 when I skimmed. Sorry about that.
  1. 17" 01' Lincoln LS rims Fit on a 90 SC. Now I know.
    By BlackAnSC in forum Non Technical Forum
    Last Post: 07-27-2004, 02:18 PM
  2. Will these RIMS fit?
    By SCollord90 in forum Technical Forum
    Last Post: 05-07-2004, 01:44 AM
  3. Do Corvette rims fit the SC?
    By NorthrnSCownr in forum Non Technical Forum
    Last Post: 10-09-2003, 08:27 PM
  4. Will these rims fit my SC ?
    By SuperCoupeSC91 in forum Technical Forum
    Last Post: 07-20-2003, 08:56 PM
  5. Will Cobra Rís or other Mustang rims fit my car?
    By blkthndr in forum FAQ Forum
    Last Post: 10-28-2002, 07:15 PM
