Results 1 to 6 of 6
Thread: Easy Camshaft Sensor Question.......I hope!
    Aug 2002
    Valley Lee, MD
    252
    are the sensors different for 89-93 and 94-95 or are they the same sensor. I'm having rough idle problems with my 94 SC and my 90 XR7 idles real smooth. Reading some recent posts indicate the CS may be the problem and I wanted to swap sensors from my 90 to my 94 before I go spend the $50 for a new CS.
    Ed Springer
    90 Black XR7 5-speed: 70mm TB, Fresh Air Intake, '94 Supercharger, 5% SC Pulley, Raised SC Top, I/C Fan, Under-drive Pulleys, 190 l/h Fuel Pump, 36# Injectors, Headers, Magnaflow Muffler (no cats) with stock resonators, 3:27 Gears, Ripper Shifter, 73mm CL MAF (Blue Tube), Magnacore Wires, NGK Iridium Plugs and Rear Spring Air Bags.
    94 Red SC Auto: 70mm TB, Fresh Air Intake, Stock 90 SC Pulley, Raised SC Top, I/C Fan, Under-drive Pulleys, 190 l/h Fuel Pump, 38# Injectors, Headers, Raven Muffler (no cats) with stock resonators, 3:73 Gears, 76mm CL MAF (Gold Tube), Magnacore Wires, NGK Iridium Plugs, TRANSGO Shift Kit, Pro-Torque 2500 Stall TC, Haydon Auxiliary Transmission Cooler, Tokico Struts & Shocks, American Racing 17 Sniper Wheels, Michelin Pilot Sport A/S Tires and 235 RWHP with 315 LB-FT Torque.
    Dallas, TX
    5,745
    The cam sensor rarely causes a rough idle. If you suspect it, simply unplug it and start the car. It may take a few tries, key off, to get it to start, but once running it should run fine w/o it.
    I suspect you have some other problem though.
    Madison, Ohio
    17,665
    Quote Originally Posted by edspringer
    Ed Springer
    They are the same.
    Email me here.
    Albany, NY, USA
    999
    Maybe what Ed is concerned with is...
    The alingment of the Cam Sensor. In other words, is it synchonized correctly?
    Aug 2002
    Valley Lee, MD
    252
    Thanks for the help and info!
    I thought they were the same but just wanted to make sure.
    The CS is aligned properly. I have the Ford plastic alignment tool and it is set at 26ATDC.
    If I EVER find out why this sucker is idling rough I surely will post the fix since rough idle seems to be a popular problem.
    Ed Springer
    Albany, NY, USA
    999
    Ed...
    When I removed my timing cover, I never bothered to use an alingment tool. I made sure to paint the area to line it back up when I reassembled. Seemed to work, but who knows maybe it's off..
  1. Easy (I hope) thermostat q.
    By bauble in forum Technical Forum
    Last Post: 05-04-2004, 05:49 PM
  2. for the last time easy wheelhop stop
    By mannysc in forum Non Technical Forum
    Last Post: 04-08-2004, 09:11 PM
  3. Is the Camshaft Sensor Easy to Change?
    By SC-71 TBIRD in forum Technical Forum
    Last Post: 12-13-2003, 09:06 AM
  4. Stock Camshaft Identification???
    By SeanMatteson in forum Technical Forum
    Last Post: 02-11-2003, 12:06 PM
