Results 1 to 5 of 5
Thread: Need Balancer BHJ or stock for 91 SC
    Sep 2004
    8
    As the title says need balancer/pulley for a 91 sc case of the broken balancer broke and the car is out of commision Can someone help me out.
    Feb 2003
    Phildelphia, PA 19030
    2,181
    Talking may be getting one
    Quote Originally Posted by testpilot
    picking up a short block this weekend will get back to you
    Howell, NJ
    1,707
    I have a stock balancer in good condition with matching crank pulley. $25 shipped in US. Let me know!
    May 2003
    LAS VEGAS, NEVADA
    149
    Better get a NEW one, the stock balancers are "one-use" only....the aluminum is permanently stressed after it's pulled off the crank...got thirty years in this business and I can tell ya, the $350 bucks for the BHJ balancer is a bargain compared to losing a $3500 engine job... problem is no one else makes a 3.8L SC balancer besides BHJ...
    remember to get the lower pulley neutral-balanced before installing on the BHJ replacement
    Trying to imitate a 455 Olds with a Ford isn't easy, but it gives me a lot to think about.
    Talk is cheap because supply exceeds demand.
    Feb 2003
    2,181
    do you have the bolt and washer????????
    Quote Originally Posted by joenintiesc
    do you have wooddruff key as well as above parts, and are you in mercer county as well??
  1. I found this FAQ on the SC
  2. BHJ Damper Update
    By gldiii in forum Non Technical Forum
    Last Post: 10-26-2004, 10:37 PM
  3. Balancer bolt broke twice
    By james5275 in forum Technical Forum
    Last Post: 07-24-2004, 01:10 AM
  4. index pointer and BHJ balancer gap?
    By RichM in forum Technical Forum
    Last Post: 04-24-2004, 09:43 PM
