Results 1 to 7 of 7
Thread: Code experts;What do these codes mean??
    Aug 2002
    Maryland
    199
    Exclamation Code experts;What do these codes mean??
    I pulled codes 92 and 74. Now the book says that 92 is a shift solenoid failure, and I dont know what that means on a manual tranny. Also, the code 74 is saying my brake switch on of failed. My brake lights do not come on unless I am really hitting the brakes hard, So I would assume that my brake switch is almost toasted. But the 92 is quite concerning. Any help on this would be greatly appreciated. Thank you for your time!
    Aaron
    asheets1@umbc.edu
    P.S. Does this pic look like what the brake switch for our cars???
    Dallas, TX
    5,680
    Yes. That is your brake light switch. Replace it. They're cheap.
    Jul 2004
    Salt Lake City, Utah
    1,519
    I'm guessing that the two codes are related, i.e., code 74 caused you to get code 92 even though it's a manual tranny. So resolving code 71 will hopefully fix code 92.
    Jan 2008
    Salina, KS
    18
    shift solenoid
    I read my codes with the key off. I got a code that said the shift solenoid needs some attention. what would it be im clueless im not to familiar with this any help would be appreciated!
    PNW
    6,538
    This is a link to a list of SC specific codes:
    http://www.njtacc.com/tech/eec_codes.html
    Sorry, how did you read codes without turning on the key....?
    74 [KeyOnEngineRunning] Brake on/off switch failure
    If you did a KOER test and failed to hit the brake pedal when expected, you'll see this code...repeat the test and hit the pedal when the reader says...
    92 [KeyOnEngineRunning] Oxygen sensor indicates system rich, left side
    If the engine isn't up to operating temp, it is possible to see an oxygen sensor code that is not valid.
    See this thread for KOER how-to:
    http://www.sccoa.com/forums/showthread.php?t=45713
    Ken
    Jan 2008
    Salina, KS
    18
    sorry i should have been more specific i did an engine off scan not key off poor choice of words on my part
    PNW
    6,538
    Quote Originally Posted by 1_Bad_Bird View Post
    Thought so As it stands now, I'd say you've learned zilch in terms of anything code related.
    When running codes, the engine should be at operating temp and a full test should be run. KOEO first, then KOER - stored codes will follow.
    Otherwise you can simply pull/clear stored codes if you like, but without a proper sequence, and being new at this, you're running the risk of confusing yourself - feel free to improvise after you learn the right methods
    Remember, codes are just something to point you towards possible issues. Never replace a part based soley on a code and never assume a sensor/component is ok even when a code is absent. Also keep in mind that one issue can look like, mask and/or affect another. A simple vacuum leak (for which there is no code), can cause a false oxygen sensor code, as an example.
    Pulling codes is part of an overall troubleshooting flow: Warm engine - Pull codes...isolate culprit(s)...check item(s) and related connections...repair...clear stored codes and repeat. Don't ignore the ability to do a 'wiggle' test as well if possible.
    Ken
  1. resetting keyless door pad?
    By obucina in forum Technical Forum
    Last Post: 08-31-2006, 03:00 PM
  2. Looking for proper way to do KOER test
    Last Post: 04-22-2005, 11:58 PM
  3. engine knock, did some stuff, ran codes, code help
    By Shooter_Jay in forum Technical Forum
    Last Post: 04-18-2004, 08:35 PM
  4. Tach acting funny
    By layinthesmack31 in forum Technical Forum
    Last Post: 10-16-2002, 01:26 PM
