I need an engine oil dipstick!!!!!!
edspringer
The dipstick in my 94 broke off at the full mark. Tough to see when I'm a quart low. Will any 3.8L dipstick work or do SCs have there own special dipstick? If they are all the same, I'll go to a junkyard. The SC dip stick is no longer available from Ford or Green.
Anyone have one they want to sell?
Ed Springer
90 Black XR7 5-speed: 70mm TB, Fresh Air Intake, '94 Supercharger, 5% SC Pulley, Raised SC Top, I/C Fan, Under-drive Pulleys, 190 l/h Fuel Pump, 36# Injectors, Headers, Magnaflow Muffler (no cats) with stock resonators, 3:27 Gears, Ripper Shifter, 73mm CL MAF (Blue Tube), Magnacore Wires, NGK Iridium Plugs and Rear Spring Air Bags.
94 Red SC Auto: 70mm TB, Fresh Air Intake, Stock 90 SC Pulley, Raised SC Top, I/C Fan, Under-drive Pulleys, 190 l/h Fuel Pump, 38# Injectors, Headers, Raven Muffler (no cats) with stock resonators, 3:73 Gears, 76mm CL MAF (Gold Tube), Magnacore Wires, NGK Iridium Plugs, TRANSGO Shift Kit, Pro-Torque 2500 Stall TC, Haydon Auxiliary Transmission Cooler, Tokico Struts & Shocks, American Racing 17” Sniper Wheels, Michelin Pilot Sport A/S Tires and 235 RWHP with 315 LB-FT Torque.
