Results 1 to 15 of 17
Thread: What stock replacement piston / Shop problem?
    Sep 2003
    Oceanside, California
    794
    Question What stock replacement piston / Shop problem?
    Ok, here's me trying not to rant.
    I took my engine into a machine shop for a hot-tank, mag, cleaning of cylinders, and balancing of rotating assembly(Fly-wheel, BHJ, crank, rods, pistons, fly-weel, and pressure plate).
    The problem comes in that one of my pistons was smaller than the rest (.005 i think). So the shop recommended that I get a replacement. (if the replacement came in as a different weight than the others, then he recommended getting a new matching set of pistons).
    So far, he's had to return 2 pistons because they were not the right ones?
    this is the first time i'm having this kind or work done, so can some of you with experience let me know if it's time to pull out from this particular shop, or maybe tell me what part I need this "GUY" to get? So that I can finally put my car back together?
    Oh, time wise, this is going on just over a month now. needless to say, the rest of the rebuild is done, and awaiting the motor).
    Thanks.
    Lakeville, MN
    13,517
    Sealed Power H675P are stock replacements according to this thread:
    http://www.sccoa.com/forums/showthre...t=stock+piston
    Sep 2003
    794
    thanks, any thoughts on my "undersized" piston?
    Lakeville, MN
    13,517
    Not sure what "undersized means". It's not the piston that's small, it's the cylinder bore that's bigger.
    Have all pistons been pulled? Have they and the bores all been checked to ensure they are round?
    I've not gone through such a process, only read about it. From what I understand, usually if the cylinder bores have worn past a certain point, new, oversized pistons are in order. Then the block is bored oversize to get the bores round again. But you don't bore the block until you have pistons in hand so you can match the size to the piston size.
    So if you have one cylinder that's a little large, it may be time to even it all out and replace all the pistons.
    Hopefully someone with more rebuilding experience pipes up.
    Sep 2003
    794
    Nope, he was pretty clear that the piston was undersized. I think he's referring to the skirt area of the piston.
    No mention was made in regard to cylinder size being an issue. The cylinders actually looked quite good.
    I am trying to NOT overbore the motor. But maybe if this new piston ever comes in, I'll have a little more information.
    Apr 2003
    Arizona
    526
    Mike, the skirt of that one particular piston has probably "collapsed", causing the smaller dimension. John
    Nov 2002
    Syracuse, NY
    504
    i'm using ross forged pistons for a 351. they run about 500 bucks though. you get an oversize piston from advance auto for 20 bucks a piece. they only list one size for the sc engine.
    check it out.120 plus tax isn't to bad for a set of new stock style pistons.
    good luck,
    joe
    Dallas, TX
    5,693
    Fellow I used to work with was a quality assurance engineer and had a job years ago to examine the best way for a production line to ensure that a block+piston assembly didn't have to be made as a set. Turns out that the factory was open to the air with great big windows at the top of the roof and that the temperature inside the factory would vary from season to season. So as long as the pistons were made and block bored on the same day, no problem, but if a block was bored on a different day, it had to be adjusted due to the difference in the piston size from the temperature.
    His paid conclusion was to buy an airconditioner. However, due to the cost of running a factory size A/C, they concluded that they would just keep building them the way they were.
    Moral of the story: the size can vary based on time of year. This is evidently why you have to have a piston fit and why they recommend you replace all of them with 1 soze over. I suppose you could keep trying individual ones until you got a match, but that takes time and luck.
    Nov 2002
    Syracuse, NY
    504
    Good Point!
    Sep 2003
    794
    Thanks for the input guys.
    Well, I talked with the guy tonight, and he said that the second piston already came in, and that it was 20 grams heavier than the rest of the set. Then he tells me that he had ordered a complete new set, $30 a piece, and that they were sitting on his desk. Wow, wish I was kept in the loop and told that the second piston had already arrived and was weighed.
    He says that he got the Sealed Power H657P pistons. So, that's good.
    He also mentioned that the one cylinder was oversized as compared to the rest because of the collapsed piston. Is that what happens? Therefore, he recommended to bore it "20" over. (0.020 right?)
    My only concern with the over bore is that now I'll have to get another set of rings to match the new bore. (anyone want a stock set of rings?)
    Also, what about the new C.I.D. size? Do I need to get an EEC tuner and compensate for the change in cylinder volume and (I'm assuming) change in compression?
    summary:
    1. does a colapsed piston necesitate an overbore?
    2. what are the ramifications of an overbore regarding engine performance?
    Dec 2003
    311
    No tuner is needed, and the compression shouldn't change, only the cylinder size.
    NICK
    Sep 2003
    794
    ok, but the only reason I mentioned the tuner was that (from my research) I've found that the EEC-IV has a setting for engine size.
    Lakeville, MN
    13,517
    Quote Originally Posted by MikeKanterakis
    summary:
    1) It all depends. The only way to be sure of anything with the engine is to measure the cross sectional diameter of the cylinders in multiple locations to check for out of round. Any change in the piston can influence the wear pattern in the cylinder. The point is, there should be no guessing. Your machinist should have hard numbers for what the issue is in the clyinders. Personally I guess I'd like to hear what the actual dimensions are that he came up with.
    2) Shouldn't be an issue unless you are trying to get max power. The volume change shouldn't be outside the ability of the EEC to compensate.
    Here is a good thread regarding rebuilding a motor that might have valuable info for you:
    http://www.sccoa.com/forums/showthre...highlight=bore
    Sep 2003
    794
    that was an excellent post. Thanks for referring me to it.
    Can I voice my desire that we have a FAQ, member's only or not, that walks us through the machine shop experience. It would be nice if we could all chime in regarding our experiences with different machine shops too.
    Sep 2004
    from alaska, living in NC
    91
    How do I word this...?
    Here's the deal, I want to make an SC engine strong enough to handle lotsa power...I plan on doing an entire rebuild myself. A few questions...
    1) Can I do this myself (with proper tools of course)?
    2) I'd have the heads, crank, and bearings done by a shop.
    3) I do have experience building an engine, just not a V-6..only have V-8 experience.
    Not trying to hijack the thread or anything, but I thought this would be a good place to start instead of starting a new thread. Thx in Adv.
    MN12
  1. I found this FAQ on the SC
  2. HELP with misfire problem
    By trench in forum Technical Forum
    Last Post: 09-23-2007, 11:41 PM
  3. Latest problem...and the search for the cause!
    By Bill McNeil in forum Super Coupe Club of Ontario
    Last Post: 05-07-2003, 10:14 PM
  4. stock MAF electronics
    By hytorksc in forum Technical Forum
    Last Post: 05-04-2003, 12:51 PM
  5. My electrical problem is becoming ever stranger...
    By Johnny_Squirrel in forum Technical Forum
    Last Post: 08-23-2002, 09:29 PM
