Results 1 to 9 of 9
Thread: 70MM MAF (cutting)
    Langley, BC Canada
    601
    70MM MAF (cutting)
    Ok guys i have 1991, and looks like it came with the 70MM MAF, now where is the part your suposed to cut out? i heard of people doing this, just wondering if there is a tech article anywhere, or if anyone can tell me, Thanks.
    Lakeville, MN
    13,517
    MN12 has an article with pictures.
    http://www.mn12performance.com/mn12how-to/maf/maf.htm
    Langley, BC Canada
    601
    Hey thanks for the help dude. Why do you re-drill the sampling tube?
    H-Town Tejas
    2,891
    In order to keep the relationship between the sampled air and unsampled air the same. If you donít enlarge the tube logic says that there will be more airflow through the meter but will not be read, so the engine would run lean until the O2ís bring it back into spec. It isnít advised to do this mod, though most have not reported any real problems that I have seen. This topic gets debated fairly often.
    Jeff
    Langley, BC Canada
    601
    Question
    Hmm so you say not to cut it?
    Lakeville, MN
    13,517
    The issue is that mechanically modifying the hard part to try to fake out the software is not a perfect science.
    If you don't mind screwing around with stuff trying to get it to work right, then the mod might be fun.
    But if you get frustrated easy, it would probably be more with your time and effort to get an optimized system from someone that is setup correctly to start.
    You're messing with the way the engine determines how much air is available to be burned. Wrong information due to mods can cause too rich, and/or too lean conditions anywhere along the power band.
    Langley, BC Canada
    601
    Exclamation ok thanks
    Yea i won't go with this, i'll wait till i get a 76mm thanks guys
    Muskegon, Michigan
    207
    Lightbulb what does my 90sc come with stock
    what is the mm of the stock maf
    Langley, BC Canada
    601
    Mine is a 70MM, and i was going to cut the center section out..being yours is a 1990 its a 55MM
