Page 1 of 3 123 LastLast
Results 1 to 15 of 31
Thread: Blower rebuild instructions
    May 2003
    Omaha, Nebraska
    6,207
    I have a complete rebuild kit for my Eaton M90. I did not receive detailed instructions for installing all the seals & bearings. I have replace some of the seals and bearings in a M90 before but not a complete replace everything including the rotors. I am sure I will get it done but instructions always help get me by any sticking parts in the rebuild. Any help would be appriciated. Thanks.
    Oct 2002
    Lincoln, NE
    2,062
    Do you need the ones I used? Or more specific? I can dig those up... Are you talking the front rotor bearings too?
    May 2003
    Omaha, Nebraska
    6,207
    Quote Originally Posted by 007_SuperCoupe
    I read in other threads that the only one that has the seals for the rotor pack is Magnum Powers. I still have to check the kit I have and see if they were included. I got the kit from Wynn. I have the rotors and the front end plate as a unit. I am concerned that the seal might not be OK as it is not a brand new rotor pack. I could use a copy of your instructions. Is there any way you could fax them to me? If so the number is 402 341-3202. Thanks for your reply Sam, I appriciate your help
    Tejas...home of Stevie Ray Vaughan
    1,748
    Quote Originally Posted by kenewagner
    ouch, that hurt!
    The way I type it would take 2 weeks to do up a set of instructions and it would take you 3 days to read 'em. By the way, the seals in the blue/black boxes are the rotor seals.
    I have a super-simple "trick" for gettin' the gears off the rotors, so easy my cat can do it but it's impossible to explain in type. Gonna be outa pocket until Monday mornin' but maybe someone here can help.
    "I read in other threads that the only one that has the seals for the rotor pack is Magnum Powers."
    Magnum Powers sells a rebuild kit? Since when?
    'bird
    May 2003
    Omaha, Nebraska
    6,207
    Quote Originally Posted by tbird88
    ouch, that hurt!
    'bird
    Wynn: Sorry, didnt intend to inply I was shorted in any way. Everything I have bought from you has been great and you have a totally satisfied customer here. I started looking at threads concerning the rotor pack and it seemed to be complicated. The threads said Magnum Powers were the only ones that had the rotor pack seals and that they did not sell them seperately, only through a rebuild of the supercharger its self. I bought these teflon coated rotors and want to get the install right the first time I wont be rebuilding the SC untill next week so I am not under the gun
    Jul 2003
    Ottawa, Ohio
    5,401
    i am in the same process you are. how to get the shaft out of the front and to remove the rotors. Where did you get the teflon coated rotors at, or did you have it done? what did the inside of your case look like mine is pretty rough. next month i am plannin on gettin a rebuild kit from wynn,
    SCCoA Member#: 2515
    1990 SC AOD 2.1L Kenne Bell
    11.676 @ 121.35 mph
    506hp/478tq
    May 2003
    Omaha, Nebraska
    6,207
    Quote Originally Posted by rzimmerl
    I got the teflon coated rotors from a GP web site. They are still in the front plate so I have not removed them. I hope to call and get ahold of wynn Monday to get his way of removing so I can have the rebuild be a through job. My case had a few scratches in it. If you get a rebuild kit from Wynn you wont be disappointe he's a standup guy
    1,748
    Due to obligations...girlfriend is sellin' jewelry at the fleamarket this weekend and yours truly HAS to sit there with her and endure all this girly-stuff...please don't tell anyone, especially j57ltr!
    Let's see if I can keep it simple. If you don't understand this completely then please don't try it. Like I said, I'm terrible at typin' so I don't really explain myself well at all. Probably confuse the heck out've you on the phone too, ask any Canadian.
    Make a mark on the rear of the rotor pins where they stick out of the back of the rotors. A fine point sharpie works great for this.
    Take a steel plate (3/4" thick will do) that measures 6"x8" and drill two 3/4" dia. holes in it that line up with the rear pins on the rotors.
    Stand the rotor pack on end, gears facing up, rotors sittin' on the plate with the rear pins facing down in the holes.
    As a buffer between the ram and the rotor pin you want to press, set a small chunk of 1/2" round bar stock on top of one of the rotor pins. Make sure this little chunk is cut nice and straight/square/etc. It's a sacrificial item but needs to be true.
    Come down with the ram on the chunk/rotor pin and press it until you get the initial break/snap/crackle/pop/creak. Technically, what you are tryin' to do in this stage is to press the rotor pin down through the rotor. Press it down ONLY enuff to get the initial "pop", 1/32" is plenty.
    Do the same procedure again with the other rotor/pin.
    You now have the initial break done between the rotor pin and the gear.
    You've also loosened the hold that the inner race of the front rotor bearing had on the pin.
    Now...Take the plate with holes out from under the rotor pack.
    Set the edges of the rotor bearing plate on some blocks and let the rotors hang free.
    Lift the rotor pack up a tad and place various types/shapes of steel chunks/blocks up under the the rotor plate.
    Using your best judgement, locate these pieces into the nooks and crannies of the rotor lobes to where they'll provide a decent surface for the bearing plate to rest on.
    Grab your little piece of 1/2" barstock and put it back between the ram and pin.
    Have a bud ready to catch the rotor and start pressing.
    If you have the bearing plate supported halfway decent at all then you shouldn't have a thing to worry about at this stage. Should only take a few hundred pounds of pressure and the rotor will start droppin'.
    note to your helper: CATCH THE ROTOR!
    Repeat for the other rotor.
    Move everything off the press and take that rotor and set it up in the press with the gear end facing down in one of the holes in the 3/4" steel plate.
    Usin' your little chunk, press the pin back through the rotor that tiny 1/32" that you moved it in the first stage.
    Watch the mark you made with the sharpie so you know when to stop. This will restore the pin in its original location within the rotor.
    Do this NOW, do NOT wait until later.
    Fingers are sore from typin', I'll do my best to press some rotors Monday and take pics of the process. It ain't magic, just common sense and a little bit've logic.
    'bird
    kenewagner - my mistake, many thanks for the compliment
    May 2003
    Omaha, Nebraska
    6,207
    Talking
    'bird
    Pictures would be awesome. Thanks for the sacrifice of your fingers on the typewriter
    1,748
    Here we go...
    Overall view of the rear rotor pins and the plate they're goin' into.
    Plate set up on the press, ready for the rotor pack.
    Standing the rotor pack on the plate and slippin' the pins into holes.
    Rotor pack in place on the plate, pins are down in their respective holes.
    I changed rotor packs for pics of the dirty work. Ram positioned over the pin to be pressed.
    Piece of 1/2" steel round bar used as a sacrificial chunk, placed on the pin to act as a buffer.
    Press until the initial "POP", only 1/32" or so of travel down through the rotor is needed.
    As mentioned above in my novel, set the rotor plate up with various pieces of stuff in strategic locations and press on the pin again. Rotor will slide down somewhat easily now and fall out the bottom.
    this help?
    'bird
    May 2003
    Omaha, Nebraska
    6,207
    Here we go...
    this help?
    'bird
    I have all the equipment to do the job so it should be a cake walk. Only question I have is when installing bearings, is there a danger of damaging the bearing. I have pressed on bearings and diffrent kinds of bushings before, would freezing the rotor shafts in the freezer over night help when pressing in to the new bearings? Thanks for all your help bird. You and some of the other guys on this site always come through with helpful information.
    1,748
    In this case stand the rotor pins on a brass buffer plate, use pipe to press on the inner race of the bearing.
    tip: don't forget to put the rotor seals in first LOL!
    'bird
    Oct 2007
    1
    How much pressure required
    Hi all, new guy here
    Im wondering if tbird88 can help me out with a few questions on this. I have tried using a hydraulic press for the first step as shown in the great description from this thread, we ran it up to 3 tonnes pessure with no sign of anything moving at all. I wasn't brave enough to go higher with the pressure as im not sure how much maximum can be applied ?
    If I do successfully remove them and replace the bearings and seals will I have a difficult job re-timing the rotors ?
    Im in the u.k. and although I could ship the unit to magnusson or Wade at hsl I just dont think I could suffer the shipping, taxes, and duty charges which is why ive read this whole thread several times over the past 2 weeks.
    Any advice would be great.
    Mick
    May 2003
    Omaha, Nebraska
    6,207
    Quote Originally Posted by roadsterguy View Post
    Mick
    This is a old thread you ressurected. I did install the new bearings. The problem I ran into is the timing of the rotors is very critical. In my case the blower ran for a while always making some noise. It ended up trashing the rotors. It is possible to time them I just didnt get it done, I had talked to Tbird88 who although posted some pictures of it how it could be done hadnt done one himself. He has since disappeared from here. I recommend paying to have it done, if it has problems at least you have warranty that you could possibily fall back on
    Ken
    Jul 2003
    Eastern (nee Western) PA
    4,993
    I recently rebuilt a blower snout, which was not too hard. I haven't torn into the rotor pack, but I think you could time the rotors if you did.
    Disclaimer: This is all untested ...
    My idea would be to drill two holes in a plate that are precisely located to fit the rotor pins. (Alternatively, maybe you could use a cut-up blower case for this fixture.) Then you could use feeler gauge stock (those super-thin strips of metal) to shim between the rotors where they meet and make sure that the clearance is the same on both sides. Then you could lock the rotors in place (maybe using a dab of some glue that you could remove after you are done). Then line up the gears in a similar way (using shim stock again if necessary) and press them on.
    One other word for the new fella: Rotor packs from recent GM cars equipped with M90 superchargers are interchangeable with these rotor packs. They have two key benefits: first, they are much newer; and second, they are coated with an epoxy coating which increases efficiency (an improved version of the coating on the 1994-95 Thunderbird SC blowers). All you have to do is drill and relocate some locating pins. So, this could be a good "Plan B" for you, if not "Plan A".
    God bless!!!
    Former Birds:
  1. Blower Rebuild Kits???
    By nighthawk in forum Technical Forum
    Last Post: 05-26-2004, 11:39 AM
  2. blower rebuild
    By dakotaflstf in forum Technical Forum
    Last Post: 02-10-2003, 06:35 PM
  3. Once Again... Blower Rebuild Parts ???
    By SeanMatteson in forum Technical Forum
    Last Post: 11-01-2002, 07:16 AM
  4. blower rebuild
    By 90xr7reborn in forum Technical Forum
    Last Post: 09-09-2002, 12:41 PM
