Results 1 to 7 of 7
Thread: Are these vacum lines right?
    Jan 2004
    Ohio/NC
    1,135
    Question Are these vacum lines right?
    jsut as the question states are these vacum lines right? its a 94 if that matters, i have been trying all day to figure out what is wrong with the car.
    thanks,
    tyler
    1#
    2#
    3#
    4#
    5#
    6#
    7#
    Jan 2004
    Ohio/NC
    1,135
    and what lines am i missing? and where would they be, i cant find any.
    tyler
    790
    I can't tell you where each 1 goes but I can tell you that anything that is left unplugged will cause you problems. If a hose of similar size is within reach, plug it in. Like the 1 on top of you plenum behind the t-body. Right now, I would be surprized if you engine runs. Good luck
    Sep 2002
    Outside of Chicago
    1,075
    First, re-install your under support for the wiper cowl, as there is a vacuum junction on there that is needed.
    The green line covered in loom goes to the egr valve.
    The red goes to the junction on the cowl support
    from the juction on the cowl support, one line goes to the
    splitter in pic#5, the blower inlet, and the T to the right of the brake booster.
    from the booster T, a line goes to the booster, others i'm not sure of.
    On the return plenum, a line goes
    to the FPR, and the line for the boost gauge in the car.
    And on the open line in the pic#2, there should be a hose from the
    pcv valve that makes a 3 way split between the inlet, valve, and line
    running to by the airbox.
    This should help you a lot, print it out to have by your side during re-assembly.
    Tulsa, OK
    767
    I got this picture courtesy of the TBU. This is for a 94-95 SC
    Findlay, Ohio
    241
    Pic #1: Nothing gets attached next to that wiring harness. I believe that is the BAP sensor (barometric air pressure).
    Bristol, CT, USA
    1,121
    i'm glad someone said that "BAP" (i was told u dont need a vacum to it) i was just looking at it and thought of the same..
    i think i know your problem that greenish Vacum line that goes to your BAP sensor now, i think goes to your heaterbox i just took my whole dam dash apart and gutted it. getting rid of junk i dont need i think i remember a greenish hose, plugged inside by the heater box..
  1. Vacum line...
    By Trick in forum Technical Forum
    Last Post: 01-04-2004, 06:03 PM
  2. Vacuum lines for the Supercharger
    By BlckbirdSC in forum Technical Forum
    Last Post: 02-06-2003, 03:29 AM
  3. transmission lines
    By madfordz in forum Technical Forum
    Last Post: 01-24-2003, 02:19 AM
