EECDOC
Dave, nearly 5 years ago I posted the information Of what I was running. Guess what I'm still running the Level 5 axles, set up as I posted. No failures In 5 Years. 1.44 60' times to date.
I did mention that I thought the stock 03-04 Cobra axles might work on the Mn12 cars. I've heard of several people running them since My post. You building a hybrid axle combining both is a great idea. The problem with it is the outer joint/stub shaft that goes into the hub. The same 28 spline outer shaft is the weak point. It will twist off after so many Hy torque dead hook launches. The upgraded 33 spline level 5 outer joint is the answer. But what do I Know, I'm just a V8 guy.
Good luck with your Project.
