Results 1 to 2 of 2
Thread: Front Hub Question...
    Long Island NY
    183
    How can I tell if my front hub is going bad. I'm guessing it is cause I hear a vibration from the front passenger side. It almost feels/sounds like I have a tire with some serious tread on it.
    790
    Hub testing
    Raise the wheel off the ground, grab the tire front & rear wiggle it in & out to see if it has any play. Then grab it on the top & bottom and wiggle it to. If there is any movement, the hub bearing is bad alot of times they will even howl as you drive.
