I need bolt my heads back down and i don't have the specs for the studs any more. What is the torque sequence and amounts for arp head studs?
Thanks,
Kyle
if you call your local autoparts store they will have all the information you need. it's a pain in the butt,you have to torque them down then back them off and torque them again. it's like start at 30 and work your way to 54 then back them off a half a turn then torque them again. don't take this as gospel. call for the exact way. good luck Bill
arp studs do not require to be torqued in steps like regular bolts, but do need to be in the correct sequence. believe they get torqued to 65 ft/lb but i wanted to make sure...oh well, i'll figure it out
