Results 1 to 7 of 7
Thread: Factory Alarm goes off after p/lock is used
    Nov 2002
    Portland, ME
    43
    When I use the power lock button the ALARM light goes solid and then triggers after 30/40 seconds. ALARM light flashs when car is off and door is open, if I just press the lock plunger down light goes out when door is closed and all is good. How can I fix this without sending a neg pulse to the disarm wire(dr green)when the power lock is pressed and bypassing the alarm. I know the alarm isn't that good but I want it all working correctly. Any ideas would be great.Thanks for the help.
    Sep 2002
    etobicoke
    268
    I've got the same problem with my 92.let me know how you make out.
    John
    Jul 2004
    Salt Lake City, Utah
    1,521
    You may have a bad trunk lock switch which triggers the alarm as soon as it is armed (after the 30 second delay).
    The trunk lock switch should not have continuity between the switch's terminals. Alternatively, check that the brown/white wire at the module is not shorted to ground.
    Nov 2002
    Portland, ME
    43
    Quote Originally Posted by J.D.
    I checked the trunk switch. OK. Tested the brown/w wire at unit and it was grounded. cut the lead and alarm is not triggering(working with p/lock now). What does the brown/w wire control.
    Jul 2004
    1,521
    Quote Originally Posted by thumpjimmy
    The brown/white wire runs to the trunk lock tamper switch. Either the wire is shorting to ground somewhere along the way or the switch itself is closed.
    Test the brown/white wire at the switch end first. If O.K. then check the switch again.
    In any case, you've found the cause of the problem.
    Jan 2004
    Tampa Florida
    471
    after you lock it and close the door the alarm still goes off??
    Nov 2002
    Portland, ME
    43
    Quote Originally Posted by debo92sc
    Not any more, after cutting the wire (brown/white at the anti-theft mod) turns out I Tested the trunk light switch not the tamper switch.
    Thanks for all the Help.
  1. factory alarm question
    By tbsc90 in forum Technical Forum
    Last Post: 03-06-2004, 08:55 PM
  2. Factory Alarm on 90SC's ?
    By pops90sc in forum Non Technical Forum
    Last Post: 01-28-2004, 09:11 PM
  3. factory alarm not working
    By SCandelous95 in forum Technical Forum
    Last Post: 12-19-2003, 10:28 PM
  4. factory alarm modual
    By william oneill in forum Technical Forum
    Last Post: 05-22-2003, 07:53 AM
  5. Factory alarm questions (adding new alarm)
    By Supacharged89 in forum Technical Forum
    Last Post: 12-22-2002, 04:50 AM
