Results 1 to 9 of 9
Thread: What would stop you from doing this???
    Jan 2003
    San Bruno, California
    137
    From all of the pics I've seen of the raised blower tops, the bottom was simply extended about 3/4 of an inch to 1 inch. So what would stop you from making a phenolic or metal spacer to do the same thing? I was going to try it anyways, then port out the stock upper cap. I am a college kid and can't afford the rediculous amount of money modified parts for this car are, so I'm getting creative. I did a bunch of this type of work on my mustang and it works fine. So......Whada ya guys think????
    Thanks.
    - Joe
    Sep 2004
    342
    The stock one kind of bends inward weird though. I supposed you could port it out a little, but it isn't going to be as good as a raised top that's near a perfect circular pipe leading into it.
    Jan 2003
    137
    I am going to do it, I'll let you guys know how it turns out and how long it took. I guarantee it will cost less.
    Raising the top is not the point of a raised top, the increased exit area that you can create by raising it is. You're not gonna gain anything by just slapping a spacer in there. You're not really gonna gain much from a real raised top anyway.
    20,947
    Quote Originally Posted by joe debattista
    Adding the spacer won't do anything but make it taller. Like was already said..the reason for adding more material the the bottom it to allow space to make the exit hole larger. The exit hole on a stock top is squished to only about 2/3s of the size of the IC tube.
    Jan 2003
    137
    Did I mention I also can tig weld. So a bigger exit area you say. No problem. So far a see a bill of about 30 bucks for some nice aluminum plate and tubing.
    Jan 2003
    137
    though I'll probably try all of this once my motor blows up. Because it is on it's way out i think.
    20,947
    Joe,
    I think your underestimating the amount of work involved. Here's a link with several pics of what is normally done to rework a stock top into a raised top.
    http://www.sccoa.com/forums/showthre...ght=Raised+Top
    Jan 2003
    137
    That was almost exactly what I had in mind. Thanks for the pics. I am not underestimating the work. I am just not willing to pay the outragous amount of money that SC modifying parts cost. I would rather have a project that took me three days and have the same effect then pay someone 200 bucks for something I can actually make myself. I know it is a **** load of work, but I enjoy stupid projects like this where it is incrediblly to much work for not enough outcome. Though I will save those pics for sure thanks David.
    - Joe
  1. 70mm BBK TB mechanical stop adjustment
    By edspringer in forum Technical Forum
    Last Post: 10-16-2004, 09:08 AM
  2. Super Coupe dies at stop lights
    By keithw in forum Technical Forum
    Last Post: 08-12-2004, 01:32 AM
  3. Sunroof doesn't stop at closed
    By sledgehammer in forum Technical Forum
    Last Post: 06-28-2004, 07:20 AM
  4. "Funny" Songs
    By SC UL8R1990 in forum Non Technical Forum
    Last Post: 08-27-2003, 01:49 PM
  5. Idle Stutter at 2nd Stop Sign only
    By San Diego Scott in forum Technical Forum
    Last Post: 05-11-2003, 11:35 AM
