Thread: Kenny Brown Lower Engine Cradle Brace
    Adrian, Michigan
    1,365
    this item has been sold
    I'm selling a Kenny Brown lower engine craddle brace that I purchased new but never installed. I opened the box when I received it about four or five years ago but since then it's been sitting in a closet. $50.00 plus whatever shipping is to your zip. PM me if interested.
    SCCoA Member # 490 since 1997
    1995 SC (five speed) 12.8913@105.86
    Best 60' 1.7489
    1994 SC (automatic) 13.4829@100.23mph
    Best 60' 1.8539 On a stock long block with bolt on's
    http://www.sccoa.com/forums/garage.p...ge_view&id=638
    Milford, Michigan
    1,398
    Jimmy,
    What is this thing? Where does it bolt to? Do you have a picture of it?
    Adrian, Michigan
    1,365
    Dan, one end bolts up to the engine cross member underneath the lower control arm mounting point and the other gets welded to the frame. One brace per side.
    From the installation instructions:
    The Heavy Duty Lower Engine Cradle Brace is designed to substantially increase the strength of the frame area between the lower firewall and the front suspension mounting points for alignment accuracy and consistency. The LECB significantly improves tightness of the chassis providing a stronger, more rigid body.
    BTW, this item has been sold.
    Quote Originally Posted by Slysc
    Jimmy,
    Best 60' 1.7489
  1. I found this FAQ on the SC
  2. Boost leaks, what they do and how to deal with it
    By Vernon in forum Technical Forum
    Last Post: 04-16-2013, 12:19 AM
  3. Replies: 0
    Last Post: 03-05-2003, 04:03 AM
  4. Kenny Brown LECB, FSSB for sale brand new
    By alfred in forum Super Coupe Club of Northern California
    Last Post: 01-16-2003, 04:12 AM
  5. Engine idles low, when in gear the idle is so lower
    By kamakazie_1 in forum Technical Forum
    Last Post: 08-20-2002, 11:17 PM
