Results 1 to 7 of 7
Thread: Changed my plugs...You won't believe...
    Oct 2002
    Lincoln, NE
    2,062
    Well, changed my plugs in the '92 a couple days ago. I'm not sure how it ran. Apart from the obvious age and wear of the plugs, I gapped one, just to see. Well, the gap amazed me. It was an astounding .073! No wonder my SC was slowing down over the course of the summer, even with mods. Last spring it ran a 15.007, then with more mods it later ran a best 15.3 then this last fall it ran a best of 15.5. But mods were installed between the first and second time I went to the track. Now I've got full exhaust, roller rockers, new plugs, and 5% pulley over what my mods were then. The new plugs I'm sure will help greatly. I'm just amazed that my SC ran at all with those worn and massively gapped plugs. (And yes, I'm sure they were the original plugs from the factory)
    Word to the wise for you guys with just a hint of idle trouble. Check the small stuff first...Plugs, wires, vacuum leaks, etc before you go further. Many times that's what it is. Just something small.
    Blair, Nebraska
    3,257
    And remember when putting your engine back together - to double check some of the little things Good luck with that today Sam.. wish I could be there when you take the first test drive.
    -Andy "Melon"
    Tricking ho's up and down the avenue
    3,078
    Bigger gap, bigger spark! RAWR
    Oct 2004
    Hawthorne CA
    300
    Quote Originally Posted by al35thsc
    hey al you mean ROAR
    3,078
    Quote Originally Posted by LostDreamer
    You say tomato....I say rawr.
    NYC
    17,431
    Doesnt suprise me one bit..EVerytime I pull plugs from an SC they are like that or worse!
    Oct 2002
    Lincoln, NE
    2,062
    Quote Originally Posted by Melon
    -Andy "Melon"
    The "little things"...Well, we never did figure out what the knocking was. We got the valve covers back off and I took off all the rocker arms...put them back on (the same way I did 2 days ago) and when I started her up, she just purred. Non of the push rods were off or anything...Not sure what it was, but she's running. Best I can figure is that she was mad at me yesterday for calling her all those names...LOL!
    Everything is good now except for an exhaust leak. I'm going to try to fix that tomorrow if the weather cooperates. I'm not sure that it will though. I'll probably end up having to take it over to a heated garage to get that done. But does she scream now...
    The really wierd thing is that I only lost about 1 lb of boost. Go figure...Fuel true dual 2-1/2" exhaust over stock and I'm still over 14 lbs of boost. I was pegging it with the stock exhaust...I'm figuring about a 3 lb loss in boost pressure from the exhaust.
    And Damon, I've never seen plugs that bad...Not even the ones that I swapped out of my '89. I don't think they were the original plugs though...These definately were. Now I've got some iridiums in there...so they should last a little while.
  1. Changed Spark plugs...car run worse?
    By Gregssc in forum Technical Forum
    Last Post: 08-24-2004, 02:54 AM
  2. How many times have you changed plugs in one day?
    By XR7 Dave in forum Technical Forum
    Last Post: 04-12-2004, 11:44 PM
  3. changed plugs/wires...plugs were kind of white!
    By SCboost in forum Technical Forum
    Last Post: 08-12-2003, 08:44 PM
  4. changed plugs and wires...sputtering gone!
    Last Post: 08-12-2003, 06:39 AM
  5. Bought some Iridium plugs today
    Last Post: 08-12-2002, 10:33 PM
