super red91 said:rubber bypass connector in good shape?
super red91 said:Its the rubber hose about 2" diameter and maybe 4" long that connects the bypass valve between the inlet plenum and the return plenum. $10 Let me know, Ryan
getblown said:What color and fabric is the interior?
jOe
unclenick said:sold items as of 1/14/05 1:30pm
injectors
headliner
turn signal lenses
sweetcoupe said:i need 2 things if you have them
one is the fan control box behind the glove box....it has to be cars with the climate control option for a 91
also need a Electronic Flasher module (a little box under the dash to the left of the steering column)
sweetcoupe said:with climate control
Mike Puckett said:Down on the frame rail below the ABS unit in the brake line is a pressure sensor. Does yours appear to be Ok, not leaking?
SloMo228 said:How do the side skirts and rear bumper look? Mounting hardware? Shipping might be a little costly, though. I'm near Detroit, zip 48088.
