Results 1 to 11 of 11
Thread: Reusing Head Bolts/Gaskets?
    Sep 2003
    33
    A few months ago I rebuilt my engine and I haven't dropped it back in yet. I purchased and installed FelPro head gaskets and head bolts. I haven't fired it up yet and the bolts have been torqued down already.
    I know that it's not a good idea to reuse them but I'm interested in porting the heads if I get a new cam. How good are the FelPro bolts/gaskets? Will I have to buy new ones or would I be ok reusing the ones I already have?
    St. Louis, MO
    6,510
    Quote Originally Posted by Flynnt
    The stock headbolts are torque-to-yield, which means you can only use them once. You will also need new headgaskets.
    Kurt K (e-mail)
    SCCoA Member #: 443
    Sep 2003
    33
    Yeah so the FelPro are considered same as stock? Wasn't sure if they were any different, since I know the stock ones are torque to yield.
    Oh well, was just an idea, scrap that. No extra money to screw around with buying all that stuff again.
    21,093
    Buy a set of APR head studs...they can be reused over and over. Since installing them I've had the heads off the motor 3 or 4 times, so for me the studs were a great investment.
    Orem, UT
    5,902
    ARP studs are nice and you can also get the Cometic MLS head gaskets which I have read are re-usable as well.
    Sep 2003
    33
    The cam purchase fell through so maybe if I blow a headgasket I'll get that stuff... so hopefully that will be never.
    Ya know......I've been wondering about Cometic gaskets! I've been using them on other engines I build and those things are great! I've never checked to see if they make them for the SC motor. hmmmmmm...........
    21,093
    I didn't know Cometic made gaskets for the 3.8. BTW, I went with Cometic MLS gaskets instead of orings on my new 347 turbo motor.
    Sep 2002
    Desoto, TX
    107
    I'm in the process of rebuilding my motor. I called Cometic a couple months ago to ask about ones for the SC. They said they didn't make them and had no plans to make them.
    Lakeville, MN
    13,517
    And thus the new thread by Mike38sc. Keep a watch on that one.
    St. Louis, MO
    6,510
    Quote Originally Posted by Mike8675309
    Here's the link to the new thread.
    Kurt K (e-mail)
    SCCoA Member #: 443
  1. I found this FAQ on the SC
  2. My head gasket how-to
    Last Post: 05-15-2009, 01:18 AM
  3. What grit sandpaper to use on block and head?
    By MikeKanterakis in forum Technical Forum
    Last Post: 05-08-2004, 12:56 AM
