Results 1 to 2 of 2
Thread: Door hinges
    Sunrise, FL
    5
    Door hinges
    I'm trying to save hours of cussing and scraped knuckles. I've got a sagging driver's door and a new "used" set of hinges waiting to go in. What is the easiest way to get the upper hinge off?
    Looks like I need to remove half the dash to get to the nut on the inside.
    Thanks, Ed
    21
    Thumbs up
    I did not even want to try to get to that top hinge nut. I got a hinge pin and bushing kit for about $7. I think it was motormite part # 38350. Just remove the door and cut the old hinge pin with a dremel. Drive the pin and bushings out and replace with new ones.
