Thread: blower top
    Canada
    7
    Question blower top
    what is the difference between the stock blower top and the self proclaimed lgr blower top, is it higher phyisically or milled out inside?
    Howell, NJ
    1,708
    Usually both. It can be anywhere from 3/4" to 1.5" higher (thus the name "raised top"), and they are usually ported out and refigured for better air flow on the inside as well.
    Lakeville, MN
    13,517
    The top of the SC is the outlet and it forces the air to make a fairly dramatic turn. On top of that, the neck of the top only is open about 50%.
    Larger tops allow for better control of air flow by smoothing the transition and then allow the neck to be opened up allowing higher air flow rates.
    From Magnum Powers website:
    Stock - Raised
