Thread: coil pack not kickin on all cylinders.
    Jan 2005
    between a rock, and a hard place
    88
    Exclamation coil pack not kickin on all cylinders.
    i decided to start pulling wires off the coil pack today, and found out that my spark isnt there on all cylinders.. should i replace the coil, the plugs, or the dis module???
    the sparks are there on all but the right 2 wires. which is coil pack#2... or cylinders 3 & 4... what would you all do in this situation?
    Imperial, MO (near St. Louis)
    4,366
    I would replace the coil pack first. It sounds like that part of the coil pack has gone bad. By the way, if you want a used one cheap, send me an email at [email protected].
    -Rod
    Jul 2004
    Salt Lake City, Utah
    1,521
    If you have an ohmmeter, then compare the primary and secondary resistance for the three coils.
  1. Tech help on a coil pack
    By BlckOnBlckBrd in forum Technical Forum
    Last Post: 09-23-2004, 11:35 AM
  2. Is Coil Pack OK??
    By MSG419 in forum Technical Forum
    Last Post: 04-27-2004, 12:32 AM
  3. No spark from 2 ports on coil pack!!
    By laroof in forum Technical Forum
    Last Post: 09-15-2003, 04:59 PM
  4. Question about coil pack
    By Greg Coleman in forum Super Coupe Club of Ontario
    Last Post: 08-24-2003, 02:23 AM
  5. Need a coil pack
    Last Post: 03-19-2003, 09:23 AM
