Results 1 to 4 of 4
Thread: Starter realy and fan relay
    Lombard
    10
    Question Starter realy and fan relay
    Does anyone know where the starter relay and the fan relay are located if so please email me so i can find them on my 94 sc
    Thanx
    birmingham, al
    381
    dunno about the fan, but I believe the starter is integral with the starter itself
    Phoenix, AZ
    40
    My fan relay was immediately behind the passenger side headlight. It is easy to get at once the air cleaner housing is removed.
    Dallas, TX
    5,755
    The starter relay (oft wrongly called the "solenoid") is the black junction assembly on the driver side wall just behind the fuse box.
    Hope this helps.
    Hint: If you're having intermittent starter problems, check that single black wire spade-tab connector on your starter motor! Its what engages the solenoid on the starter motor itself.
