Results 1 to 15 of 17
Thread: tires 255/40/17s fit?
    Oct 2003
    British Columbia Canada
    554
    255/40/17s fit on a 17X9 rim on our tbirds? no rubbing etc?
    Feb 2004
    Outside Vancouver BC
    824
    Yup. I think you can fit up to 275 without issue.
    Oct 2004
    Lake County, Florida
    870
    The 275's will fit. I have 275/40ZR18's on the rear of mine now. The car is lowered and no rubbing issues at all. The 255's will fit.
    7,586
    255-40-17 will be about 1-1/2" shorter than the original size tires. IMO 255-45-17 would be a better choice ... within 1/2" of the stockers for diameter.
    Our cars have big wheelwells, they look a bit strange with short tires on them.
    cheers
    Ed N.
    Aug 2004
    KSRQ
    5,220
    Quote Originally Posted by fast Ed N
    cheers
    Ed N.
    So what tires would you recommend if I'm using stock wheels?? I have 225/50-16's on there now, but they're a little too low and not wide enough for my taste. Maybe for the front, but the back needs a little more. Like you said, that's a big empty wheel well!
    I have stock 255/60-16's on the '92 and they're fine there, but that's too high and to thin for the '95. But tires I don't know from. It was suggested I try 245/50's? Anyone else have any thoughts??
    Ira
    Mar 2003
    Nebraska
    774
    I have 255/40/17 on my sc and I think the rubber could be taller for a better look. So I agree go taller profile than a 40. my .02
    Doug
    Oct 2003
    554
    Quote Originally Posted by Douglas Walker
    Doug
    interesting. i may have to take that into consideration. i want something thin, however not too thin that it looks like i put a body lift on my car. im gonna look into that, thanks
    21,150
    If your going with the same width on all 4 wheels, I suggest 255-45-17s. If you want a wider stance in the rear and want to keep the tires about the same diameter on all 4 tires, go with 245-45-17s in front and 275-40-17s on the back.
    I found that even the 255 will rub on the rears if the car is lowered. I put airbags in the rears springs to fix that.
    Sep 2002
    Effingham.IL
    5,011
    I run 245/45-17 in the front and 275/40-17 in the back.
    I am using Nitto Tires.These tires were the same heigth
    as my stock tires,225/60-16.
    The rims are 17/9''. With 36mm off set on the wheels.
    I have no rubbing, but my car has not been lowered.
    My SC set's a little higher than stock,because of
    some lighter parts.
    I would like to run a 275/40-17 up front and a 315/?-18 for
    the back.
    Randy
    21,150
    Quote Originally Posted by Randy N Connie
    some lighter parts.
    the back.
    Randy
    Randy,
    I need some new tires for my 93 and thinking about doing 245-45-17s up front and 275-40-17 Nitto Drag Radials on the rear. Just wondring if it looks okay without the car being lowered. Can you post a picture of yours.
    Sep 2002
    Effingham.IL
    5,011
    I don't seem to have any more tracktion with the 275/40-17
    Nitto drag radials.As I did with the 225/60-16 tires.
    The only change so far is.That I don't brake traction at 90mph.
    Its down to 75mph,Above 75mph my tire don't spin any more
    when I have OD locked out.So I guess they help a little.
    The Nitto 275 seem a little narrower than a normal 275 tire.
    I think a 285 or 315 would fit in the back.But I don't know
    if Nitto has the right heigth.I think a person would need
    to go with a 18 inch rim in the back.And a 17 inch rim for
    the front.
    I will post some pictures later today,After I take some.
    Thanks Randy
    7,586
    Randy, you are correct. The Nitto performance tires tend to be about 10 - 20 mm narrower than most other brands, for a given size.
    cheers
    Ed N.
    Sep 2003
    BUFFALO, NY
    532
    Quote Originally Posted by irar
    Ira
    Pirelli makes the Scorpion Zero's in a 255-55-16 that is only 1/2" less around than the stockers. I got mine for about $100/ ea. They get pretty good "gription" for the money.
    NYC
    17,432
    If you look at my member page thats what a lowered SC looks like with short tires.....Currently Im running kumhos with 255/50/17 lowered 1.5 inches....WHen you hit weird bumps it will rub..Keep in my I have 98 cobra rims slightly wrong offset for an SC
    Sep 2002
    Effingham.IL
    5,011
    David N. here is a picture of my SC.
    The rear tires are Nitto NT555 RII 275/40-ZR17 roadrace style not dragrace.
    Same tread size & pattern though.
    The front is Nitto NT555 street.245/45-ZR17 same pattern but smaller.
    You can get a NT555 R 245/45-ZR17 this is the drag radial.
    All of the nitto tires listed above are the same as stock tire height.
    I think that the NT555 R 255/50-ZR16 drag radial is the same height
    as stock.If you want to use the stock wheels.
    To get Nitto NT 555 tires with the drag race or roadrace tread pattern.
    And the same height as stock tire. you would need to run.
    Front NT 555 R 245/45-ZR17. This is a DRAG RADIAL
    Back NT 555 RII 275/40-ZR17 This is a ROADRACE TIRE.
    I odered a 275/40-17 roadrace tire for the back.And a 245/45-17
    drag radial for the front.They sent a 245/45-17 NT555 street instead
    of the dragradial for the front.
    Randy
  1. What size tires fit on 8.5 inch rim
    By derekhay316 in forum Technical Forum
    Last Post: 06-03-2004, 05:37 AM
  2. Wheels, Tires and Alingment. My Post-mortem views.
    By Deep6 in forum Technical Forum
    Last Post: 10-16-2003, 09:24 AM
  3. Tires, Wheels and Alignment. My post-mortem views.
    By Deep6 in forum Non Technical Forum
    Last Post: 10-13-2003, 08:33 PM
  4. OEM Tires
    By Still Crusin in forum Technical Forum
    Last Post: 03-09-2003, 12:26 AM
  5. Hmm, need some advice on tires.
    By Johnny_Squirrel in forum Technical Forum
    Last Post: 08-31-2002, 03:30 PM
