Results 1 to 12 of 12
Thread: 93-95 SC Rims Chipping.
    Dec 2004
    Marengo, Iowa
    101
    I Have A 94 SC And My Rims The Paint On Them Is Starting To Chip. Is This Normal? How Much WOuld It Cost To Get Them Redone.
    thanks keith
    Dec 2003
    Connecticut
    2,217
    Two of my rims are also chipping in my 1994sc
    Feb 2004
    St. Louis, MO
    155
    i just painted mine in with black paint... since my 90 is white with black trim... looks pretty nice.
    Oct 2004
    Howell, MI
    971
    i cant say where they can be redone, but for a price, anything can be done. However; to answer your first question, your car is 16 years old, i think that it is safe to say that it is normal to see a little wear and tear on the rims.
    Aug 2003
    Millbrook, Alabama
    155
    Hey..ThePikey....do you have a pic of your car with the black rims? I have a white SC with black pinstripes, trim and spoiler. I've tossed around either painting the wheels white to match the car or black to add to the trim. I'd like to see what yours looks like....
    BTW..for anybody who cares, the wheels are powder coated from the factory. The "paint" which comes in the form of a powder, is applied with a spray gun while the rim is statically charged. This causes the powder to stick to the rim. The whole thing is then baked in a low temp (400-500 degree F) oven until the paint melts and adheres to the metal. Pretty cool process.
    I'm sure many of you know this already and it may have already been discussed.
    Joisey Jim Guest
    I don't believe mine are powder coated. On both my '93 & '94 the silver surface is flaking, like it's clearcoated. I was going to try and wet sand them; if not successful, I thought about painting them over. I did that successfully on my wife's Escort GT (which had painted alum wheels and the plastic hub cap just like the SC) and found a Subaru silver that matched exactly.
    The chips generally are caused when the balance weights are moved and the tire shop doesn't use coated weights. The wheel on that picture above actually looked pretty good & probably just needs a little touch-up.
    Aug 2003
    Millbrook, Alabama
    155
    My 94s are definately powdercoated. The paint still gets scraped off from the wheel weights. No sign of clearcoat on mine.
    Oct 2002
    Indiana
    1,176
    Sorry-they are not powder coated at the factory-if they were we would not have the problems with finish that we do. I removed the paint on mine using an aircraft paint remover-you can't do that with a powdercoat finish.
    The paint is a special formulation used for the wheels, and then they receive a clearcoat. There are some wheels that receive what's called the bright aluminum treatment-no paint, the wheels are buffed and installed.
    Tony
    Aug 2003
    Millbrook, Alabama
    155
    Ok...I won't argue. I've looked at mine carefully and they appear to be powdercoated. I could be wrong of course. I deal with powdercoated parts on a daily basis and what I've got appears to be powdercoating. If not, it's a damn good paint. Powdercoated parts will chip and scrape also. You are correct about the paint remover though...it won't touch powdercoated parts.
    Feb 2004
    St. Louis, MO
    155
    i guess i should have been more spcific. it wasnt the rims i painted. it was the birds in the hubcaps that i painted. if you still want a pic let me know and ill post it in here.
    Oct 2003
    British Columbia Canada
    554
    mine are chipping around the edges. did all the rims come with that tbird graphic on the centercap, in the stamped thunderbird symbol?
    Feb 2004
    St. Louis, MO
    155
    i got my 90 last march... so im gonna guess no. or if it did, they chipped off before i bought it.
  1. 17x7.5 Triple Chrome Rims and 245/45/17 Tires
    By PHATBRD in forum Parts for Sale
    Last Post: 10-12-2004, 10:24 PM
  2. What's a Fair Price for Used SC rims?
    By Deep6 in forum Non Technical Forum
    Last Post: 06-17-2004, 07:55 PM
  3. I give up.... new rims question...(again)
    By Deep6 in forum Technical Forum
    Last Post: 11-11-2003, 10:30 PM
  4. Polishing 94 SC rims
    By Stelar SC in forum Non Technical Forum
    Last Post: 07-22-2003, 09:14 PM
  5. This can NOT be right! (stock rims)
    By Johnny_Squirrel in forum Non Technical Forum
    Last Post: 08-28-2002, 01:02 PM
