I last drove it in 2003. At that point I did the oil pan seal, and installed a modified SC outlet. Since the problem started after this those repairs I'm going to look for leaks in the IC tubing, and vacuum hoses first. I am also going to try cleaning the MAF, and doing the reset (batteries have been disconnected for 18 months). Odly enough, when I moved the car from home to work ( so I can work on it this weekend) it ran pretty good. The bad idle is intermittant, and does not seem to coorespond to engine temperature. So, yes I will be at work all weekend tinkering....so if anyone needs wheel alignment, or wheel balancing/vibration work done..let me know. I have access to the best wheel service equipment money can buy.
Hunter Engineering
