Results 1 to 15 of 16
Thread: Stock RWHP on SC?
    bokeelia, fl
    46
    Stock RWHP on SC?
    Does anyone know the number for sure from a dyno?
    Any info will be greatly appreciated,
    Thanks.
    Vermont
    136
    To start with....
    There are four possible answers (engine and transmission combos), and that's not including varibles like:
    Temperature
    Humidity
    Altitiude
    TC lock/unlocked
    engine condition
    transmission condition
    Just go dyno your car. It's usually less than $100 for three pulls which will all confirm each other.
    an 89 5-speed...about 178rwhp and 268rwtq
    20,939
    Assuming you are talking about an 89 with a 5 speed.
    210 HP with 15% drive train loss = 179 RWHP
    Even with the SAE corrections for elevation and temp, every dyno reads a little different.
    Vermont
    136
    Good point Dave...
    It also depends if you want SAE or STD correction.
    bokeelia, fl
    46
    thanks those will do
    Thanks those will do fine, i was just looking for an estimate, i appreciate your replies..
    thanks
    St. Joseph, Michigan
    16
    RWHP
    Would you also take away 15% for 95 autos for a rough estimate?
    Chris
    Somerset, Mass.
    632
    Go with 18%-20% loss for an auto
    Aaron
    Vermont
    136
    No....
    the 4r70w is very good for an auto tranny, it's more like 16% to 18%.
    However, pastera is correct for an AOD.
    my 94 sc auto put down 207RWHP with just a chip.
    16
    Thanks
    Thanks GreenBird. 93, is your 94 completely stock. Bill Evanoff said I should be at about 285HP at the engine with my upgrades.
    Chris
    mine is completley stock besides the chip.
    Looks like you basically have exhaust, underdrive pulleys, 5%OD, and an intake kit. I don't know if that is worth a whole 40HP or not, I'd guess that you might fall a little short of that.
    The only real way to tell is get on the dyno. Drive down to St. Louis next weekend and we are having a dyno tune. You can get a custom chip and dyno sheets for $350, and it should be worth some nice HP.
    Brian
    16
    Question SC Chip
    Have you had problems caused by your chip?Their have been some pretty extensive info passed around discussing how chips are ineffective on SC's. Their was also an article on the subject in an old Chargin Thinder newsletter.
    Thanks,
    Chris
    nah, not ones made by inject_tech, they work beautifully. The only issues that could happen is if you don't clean the service port before you install the chip you can have intermittant problems.
    My chip improves shift firmess, changes fan temperature controls, changes shift points, rev limiters, and a bunch of other stuff. There are a few others using the same chip that seem to like it.
    16
    website
    Interesting. Do they have a website?
    Chris
    Adrian, Michigan
    1,365
    93 Mark VIII is right on about the inject_tech chip. I have one in my 94 4R70W equipped SC and it does evrything stated and then some. My 94 never leaves home without it
    SCCoA Member # 490 since 1997
    1995 SC (five speed) 12.8913@105.86
    Best 60' 1.7489
    1994 SC (automatic) 13.4829@100.23mph
    Best 60' 1.8539 On a stock long block with bolt on's
    http://www.sccoa.com/forums/garage.p...ge_view&id=638
