Results 1 to 2 of 2
Thread: Timing the Camshaft Position Sensor
    Aug 2002
    Valley Lee, MD
    252
    I just read a Ford service bulletin off of the ALLDATADIY website that says the #1 cylinder needs to be set at TDC when aligning the CPS. I thought it was 26 ATDC. That is what the Ford maintenance manual says. Anyone know the real jeopardy answer?
    Ed Springer
    90 Black XR7 5-speed: 70mm TB, Fresh Air Intake, '94 Supercharger, 5% SC Pulley, Raised SC Top, I/C Fan, UD Pulleys, 190 l/h Fuel Pump, 36# Injectors, Headers, Magnaflow Muffler (no cats) with stock resonators, 3:27 Gears, Ripper Shifter, 73mm CL MAF (Blue Tube), Magnacore Wires, NGK Iridium Plugs, Royal Purple Lubricants and Rear Spring Air Bags.
    94 Red SC Auto: 70mm TB, Fresh Air Intake, Stock 90 SC Pulley, Raised SC Top, I/C Fan, 190 l/h Fuel Pump, 38# Injectors, Headers, Raven Muffler (no cats) with stock resonators, 3:73 Gears, 76mm CL MAF (Clear Tube), Magnacore Wires, NGK Iridium Plugs, Royal Purple Lubricants, TRANSGO Shift Kit, Pro-Torque 2500 Stall TC, Haydon Auxiliary Transmission Cooler, Tokico Struts & Shocks, American Racing 17 Sniper Wheels, Michelin Pilot Sport A/S Tires and 235 RWHP with 315 LB-FT Torque.
    Oviedo, FL
    1,706
    Ed... I set mine according to the Ford service manual. That was 26 degrees ATDC with the synchronizer tool. The location of 26 degrees ATDC is groove in the factory balancer. Make sure the engine is on the compression stroke and not 180 degrees out. If it is 180 out it will cause all kinds of problems. Worked out great for me... hope this helps you out.
    Bryan
  2. Wide band O2 w/ digital display in car
    By kuhnga in forum Technical Forum
    Last Post: 12-04-2004, 11:55 AM
  3. How do I realign the camshaft position sensor?
    Last Post: 04-01-2003, 10:58 PM
  4. Car only runs with diag scanner on...PLEASE HELP!!!
    By Mike Manzo in forum Technical Forum
    Last Post: 11-17-2002, 05:42 PM
  5. Camshaft sensor timing
    By 90SuperBird in forum Technical Forum
    Last Post: 09-07-2002, 11:55 AM
