Results 1 to 2 of 2
Thread: 89-92 ABS relay part numbers
    Exclamation 89-92 ABS relay part numbers
    For Rocco, and anybody else who cares, here are the Ford part numbers for the two relays used on the Teves 1989-1992 systems.
    The ABS power relay, which will probably have an original stamping of something like E3TB 13A025 A1A, the replacement number has changed a few times ... it's now F8PZ 14N135 CA, which will probably look slightly different than the original, and the dealer will sell it under a Motorcraft #, DY-866. A DY-864 could be used as well. The other relay is the ABS pump motor relay, right beside the other I believe, a brown and black relay, should be stamped something like E7LB 8Z658 AA, replacement number is E7LY 8Z658 A, and if the dealer soesn't have that on the shelf, a DY-865 can be used in it's place.
    Ed N.
    Brampton, Ontario
    thanx for the part numbers ed!!!!!!!!!
    and ill be at the shop at about 10-1030 am on tuesday
    Ill see ya then!!!!!!
