Results 1 to 15 of 19
Thread: Underdriving supercharger
    Aug 2004
    Beckville, TX
    85
    I'm going to have to use my Supercoupe as a daily driver for a while and I was wondering if they make pulleys to underdrive the supercharger so I could get better gas mileage and less wear. I've considered pulling the blower belt off completely, but it sure would be nice if I could meet in the middle and get around 8 psi. I plan on upgrading to an s-trim blower by the way (if I can find one).
    Adrian, Michigan
    1,376
    Quote Originally Posted by kenshi
    If you still have the stock 89-93 pulley on your car find a 94/5 pulley. There a little larger circumference wise and will underdrive your blower some.
    SCCoA Member # 490 since 1997
    1995 SC (five speed) [email protected]
    Best 60' 1.7489
    1994 SC (automatic) [email protected]
    Best 60' 1.8539 On a stock long block with bolt on's
    http://www.sccoa.com/forums/garage.p...ge_view&id=638
    Aug 2004
    Beckville, TX
    85
    But like I said, I'm switching to an s-trim (94-95) blower, so it'll already have that pulley and still produce full boost. At least the newer blower will produce less drag for that reason and probably better gas mileage, but I would like to step it down another notch for daily driving.
    Aug 2003
    Millbrook, Alabama
    155
    Well, if you drive it reasonalbly, as in shift around 2500 RPM and accelerate modestly (not dog slow) you will only develop about 8 lbs of boost anyway, At least thats what my 94 does. I guess I might have better control because of the 5-speed, but shouldn't it be even easier on automatics?
    I wouldn't take the SC belt off. It's much slower than a NA 3.8 due to the blower being in the airpath. I was completely disappointed with the performance of mine when I replaced the belt and had to go to the store without one on because they gave me the wrong one first....
    21,122
    Let me get this right....your going buy an S port blower because it's more efficent, and then underdrive it because you don't want to use too much gas ?
    Sorry but that makes no sense, it's only more efficent under boost. Save your money and keep the blower you have and get a good dyno tune instead. If your really concerned about the gas consumption, remove the supercharger belt and wire the bypass valve open. Then you can run the cheaper 87 octane fuel. If you want to make the car into an even slower lump of steel...pull the octane plug.
    Aug 2002
    3,669
    Yea, what David said. The newer blower should give you '20 HP', to make more power you need more fuel. But you want to lower the boost to save fuel?!
    Aug 2004
    Beckville, TX
    85
    Quote Originally Posted by RustyUL
    I have a 5-speed as well.
    Oh I've already driven it around without the blower belt since my coupler is shot. (That's why I'm replacing the blower in the first place. I could fix it, but it's a good excuse to upgrade.) It actually feels close in acceleration to my LX. That's still pretty freakin slow though.
    Aug 2004
    Beckville, TX
    85
    Quote Originally Posted by David Neibert
    Like I said, I've considered running it without the belt and have already done it some, but it's slow as hell. With the blower, I can at least pass people on the highway reasonably. Twelve psi is extreme for casual driving though. Yes, I can go light on the throttle (well... I can try), but the blower is still spinning faster than it needs to, causing more load on the engine and wearing itself out faster. I was just looking for a solution where I could meet in the middle when I'm going to work or whatever and easily change back to full boost for the weekends. I know I'm not the first to employ more moderate settings for casual street use than spirited driving or racing. Hell, the thing that gave me this idea was a V8 guy saying he was adding a blower to his setup and running 6 psi on the streets and 9 psi at the track.
    Anyway, I doubt they make any aftermarket underdrive pulleys since I'm apparently the only Supercouper to consider using one (and I wouldn't spend much on it anyway), but I figured perhaps one of the other M90 applications (one of the GM cars maybe) came with a larger pulley that could be bolted on. Hell, if I can spend $20 to $30 on Ebay for a pulley that will give me maybe 1 more mpg and a few thousand more miles on the life of my blower bearings, then I'll be damned if it isn't worth it. If there's not one, I'll just leave the belt off, deal with the sluggishness, and put it on when I'm in the mood, or leave it on and try to lighten my foot. I hope I've explained my reasons well so I can get an answer to my question.
    Apr 2005
    BC, Canada
    586
    Cant juice a turnip.
    I would just save the hassle and lighten your foot. the SC's 8:1 compression is really nice for boost, but makes the efficiency you seek impossible (in my opinion).
    Tyler (Tickler)
    1990 SC
    21,122
    Unless you push the throttle hard enough to drop the vacuum and close the bypass valve, the supercharger isn't under any load and it only consumes about 1 HP.
    Dec 2003
    Edmonton, Alberta, Canada
    95
    It's not hard at all to dive without going into boost with a 5 speed. I usually don't go into boost at all unless i want to pass some one quickly. Just lighten your foot and shift right. I usually shift @ just over 2000 rpm for fist then with less rpm as i get going. You can tool around in fifth at around 1000 rpm without lugging the engine. If you want to save on gas learn to drive a standard and don't push the gas so much! Take off slowly and keep your speed down.
    Apr 2005
    Houston, Tx
    69
    Quote Originally Posted by ipeefreely
    That's kind of what I was thinking..........I drive my 5 speed around everywhere and hardly ever get into boost. It's actually fairly easy. But then again.......I may be considered an old fart now a days........lol
    Can anyone show me where this octane plug is..........I want to make sure mine is even on my car.
    21,122
    Quote Originally Posted by LIL QIK
    Aug 2004
    Beckville, TX
    85
    If you remove the blower belt, you don't have to pull the octane plug to run regular unleaded, do you?
    21,122
    No you don't need to remove the plug if the SC belt is off or if the bypass valve is held to the open position.
  1. I found this FAQ on the SC
  2. 91 Supercharger, plenum, 10%, raised top
    By eyefly in forum Parts for Sale
    Last Post: 01-17-2005, 03:12 PM
  3. Turbo vs. Supercharging....
    By dirtybird91 in forum Non Technical Forum
    Last Post: 08-25-2004, 10:19 PM
  4. New lightweight supercharger pulleys!
    By BT Motorsports in forum Group Purchases / Specials
    Last Post: 07-11-2004, 07:50 PM
  5. 95SC 2.2L supercharger project (pics included)
    By 93 Mark VIII in forum Technical Forum
    Last Post: 12-19-2003, 09:06 PM
