Results 1 to 6 of 6
Thread: Cam Sensor...HELP!!!
    Nov 2004
    Falling Waters WV
    723
    What is the proper method of putting this piece back in so it is in time. Can you just slap it back in or what? What is the proper procedure? Thanks for any help.
    Dallas, TX
    5,754
    If its just replacing the sensor, bolt on the new one, plug it in and go. No adjustments are needed.
    Nov 2004
    Falling Waters WV
    723
    Well i put another cam on and im wondering if there is a way to put it back in time. Is it like a distributor and you can turn it or what you do to get it in time. Thanks again.
    Apr 2003
    Arizona
    526
    Yes, if you are installing the cam-sensor drive it absolutely must be installed in proper time. There are several posts about how to do it just do a search. It's a critical location. Also there is a tool available to set the drive in the proper location and it's not expensive. John
    Nov 2004
    Falling Waters WV
    723
    Thanks man.
    Joisey Jim Guest
    Go on E-bay or Spinning Wheels web site, I've seen that cam tool for about $20.
  1. 95 & 89 stock cam specs?
    By 95sc666 in forum Technical Forum
    Last Post: 02-10-2005, 11:18 PM
  2. Cam with stock heads?
    By super red91 in forum Technical Forum
    Last Post: 10-16-2004, 03:16 AM
  3. Cam troubles once again....
    Last Post: 12-01-2003, 04:21 PM
