Results 1 to 2 of 2
Thread: ABS kicks in at slow speeds
    Feb 2004
    New Tampa
    124
    On my 94 auto, when I'm braking, just before I come to a stop, say in the last 20 feet or so, the ABS will sometimes kick in. I don't believe the ABS is doing its thing on all four wheels, but I can't tell which wheel it is. Weather conditions don't matter, it'll do it wet or dry. It happens most frequently in the morning at the first stop, but it'll also do it if I've been driving for a while and come to a stop. It doesn't do it in stop and go traffic. The car had the problem when I bought it. I replaced pads and rotors and bled the system and still the same. I do have a soft pedal, and there is a drop or two of brake fluid inside the car. I'm thinking it's either the master cylinder needing replacing, or more likely a sensor needing cleaning. Anyone else had this happen?
    Sep 2003
    P-Town, MN
    2,511
    Quote Originally Posted by dms825
    My SC isn't doing this, but my '99 Contour is! I'm all ears to hear what is causing it. Same symptoms to a T.
  2. I'm Back - Abs Woes Again!!!
    By 89 BLK SC TX in forum Technical Forum
    Last Post: 09-12-2005, 07:54 PM
  3. ABS operation : slow?
    Last Post: 01-01-2004, 11:08 PM
  4. swapping abs to non abs
    By Dr-Rock in forum Technical Forum
    Last Post: 11-12-2002, 02:08 PM
