LightEMup said:is it a factory sunroof switch? i have an ASC sunroof and need a switch for it.
would a stock switch work with it?
ThePikey said:is the sunroof the ASC sunroof of the factory one? if its the ASC one, do you still have the motor?
sunny627 said:Parts List Updated 9/18/2005
If you see a part cheaper somewhere else shoot me an email and I am sure we will be able to come to a deal that we both like.
I ship via USPS Priority Mail or FEDEX Ground depending on size/shape of part.
I can do overnight, 2nd day shipping, etc
I accept Paypal, Wester Union, Money Gram, and Money Orders for payment.
Sorry No Personal Checks
Any questions please email me: sunny627@hotmail.com or cell: 651-235-0762
Thank you,
<a href="mailto:sunny627@hotmail.com">Ryan Sunquist</a>
<P>
I have many more parts available than what is listed, if you do not see it please email me and ask
1989 5-Spd, Black Leather Interior, all options available from factory. Parting Out.
DRIVE TRAIN
5-speed Tranny w/ 100k works well - $275 (Two available for $450)
Body Modifications
Window Guards - $10 for the set
Newer Replaced Parts
Wiper motor - $35 less than 10k
Driver-Rear Caliper - $30 Less than 3k
Front Rotors – less than 3k $15 for the pair
<P>
Power Line
<P>
ARC Sensors $15 Each
ARC Plastic Covers $5 Each
Intercooler tubes $30 Each
Intercooler $65 Each
Heads (complete) $150 Set
DIS Module $35
Passenger Side Motor Bracket $45
Water Pump Pulley $5
ABS brake line joiner $40
ABS Relay $20
ABS Master Cylinder Complete (Sold Out)
Fuel Harness $25
Fuel Rail $25
Valve Covers (each) $25
Inlet plenum $30
Stock Air Box $5
Stock Air Tube $5
Oil Cooler $40
Oil Pan $70
Cam Shaft - $65
Crank Shaft - $65
Intake Manifold Inlet Plenum $30
T-stat housing (Sold Out)
Timing Chain Cover $50
Cam Sensor $25
Crank Sensor $35
Belt Tensioners $30 Each
Belts $10 Each
Batter Tray $20
Horn $25
Supercharger (89-93) $200
Supercharger top $35
Auto radiator- good for getting 3 cored $40
Radiator Fan $40
Power Steering Pump Cooler $40
Power Steering Pump/bracket/top/dipstick sensor $60
Fan Control Box (IRCM) $40
Throttle Body w/ Sensors $25
Coil Pack $35
Washer Fluid Tank $15
Harmonic Balancer and crank pulley (Sold Out)
Exhaust manifolds $30 Set
Alt $45
1990 Long Block, runs great $200 Pick Up Only
Clutch pedal (Sold Out)
Clutch master reservoir $35
Clutch slave reservoir $35
Clutch hydro line $35
5-Spd flywheel $35
Main Engine Wire Harness (includes fuse box, etc..) $50
<P>
I have all misc. sensors under the hood or anywhere in the car.
<P>
Body Parts
<P>
Hood Latch $25
Hood Latch cable $25
Header panel $45
Headlights $30 Each
Corner lights $25 Each
Keyless Entry Computer $25
Keyless Entry Pad $60 (Number Pad in Mint Shape)
Black Hood $80
Titanium Hood- Little ding $50
Fuel pump $25
1989 Front Sway Bar $50
1989 Rear Sway Bar $50
Front Inner Bumper $30
Rear Inner Bumper $30
Front Rotors $10 Each
Front Calipers $25 Each
Front Hub assemblies $90 Each
Rear knuckles and Spindles $75 Each
FAT 5-spd half shaft $50
Regular half shaft $35
Rear Calipers $30 Each
Rear Caliper Brackets $12 Each
Wiper Arms $5 Set
2- lx 15" wheel inserts $1 Set
Front bumper cover-Black $125
Rear bumper cover-Black $125
Side skirts- 6 pieces- black $125
Passenger side Rear Corner Light $30
Passenger side rear trunk reflector $30
Driver Side Rear Corner Light $30
Driver Side Rear Trunk reflector $30
White door mirrors $25
White doors- in excellent shape $100 Pair (Pick up only in MN)
White Front bumper cover- side markers $125
White Front Bumper cover- no side markers $125
White GFX Set (6 pieces) $125
White Hood- little service rust $60
<P>
Interior Parts
<P>
Grey Seat Belts $30 Set
Grey lighted Sun Visors $15 Each
Grey leather rear speaker covers $30 Set
Grey Cloth Speaker Covers $15 Set
Grey Sun Visor Clips $3 Each
Grey kick panels $10 Each
Black Sun Visors $15 Each
Black Sun Visor clips $3 Each
Black kick panels $10 Each
Black Cloth Rear Seat (Good Shape) $60
Black Dash-with sliding tray (great shape) $125
All Grey panels available, just ask for avail
All Black panels available, just ask for avail
Red Cloth rear seat (Great Shape) $60
Red lighted Sun Visors $15 Each
Instrument Gauge Cluster $50
Steering Wheel-Complete $40
Black Center console arm rest $30
Black Gauge cluster finishing panel $10
Center Panel- 5-Spd has e-Brake dust guard $35
Premium sound door hand cup inserts $35 Set
Door switch holders $15 Each
ARC Switch $14
Fog Light Switch $14
Sunroof Switch (the thin switch(89-91)) $16
Sunroof Switch (thick switch(92-93)) $16
Auto-Dim Switch (dual knobs) $10
Headlight Switch $14
Headlight Switch knob $14
Antenna Switch $14
Door Switches $10 Each
Defrost Switch $10
Driver door double switch $12
Sunroof switch front panel $16
Sunroof switch panel bracket $16
E-brake Assembly $50
VMM $65 Perfect Condition w/ clips!!
Ash Tray $5
Heat Control-analog $15
Air vent panels-silver and black $30
Sliding seat belt track and motor $65 Each
Rear Quarter Glass $35 Each
Door Glass $35 Each
Window motor $30
Door lock actuator $30
Sunroof Motor $35
Sunroof Glass $25
Stock Sunroof Wind Deflector $40
Coin/cup holders (modified for the MN12) $20
VMM delete panel $7
Power Antenna Switch delete panel $5
ABS Computer $30
ARC Computer $30
1990 Auto EEC $35
JBL Speakers $20 Each
JBL Stereo Amp $30
Tape Cassette Holder for center console $5
Turn signal multi-switch $35
jpmcdonald said:Sunny, what is the 'titanium hood' like ? Who made it ? What style ? Got any Pic.? Thanks,
J.P.
sunny627 said:Parts List Updated 9/28/2005
Thank you,
<P>
DRIVE TRAIN
Body Modifications
<P>
Power Line
<P>
DIS Module $35
ABS Relay $20
Fuel Harness $25
Fuel Rail $25
Inlet plenum $30
Stock Air Box $5
Stock Air Tube $5
Oil Cooler $40
Oil Pan $70
Blocks - $50 - (Pick Up Only In MN)
Cam Shaft - $65
Crank Shaft - $65
Cam Sensor $25
Crank Sensor $35
Belts $10 Each
Batter Tray $20
Horn $25
Radiator Fan $40
Coil Pack $35
Alt $45
5-Spd flywheel $35
<P>
<P>
Body Parts
<P>
Hood Latch $25
Header panel $45
Headlights $30 Each
Fuel pump - SOLD OUT
Rear knuckles and Spindles $65 Each
Wiper Arms $5 Set
Front Bumper Cover- Black - $125
Front Bumper Cover- Red - $125
Front Bumper Cover - Titanium - $125
Front Bumper Cover- White - Side Markers $125
Front Bumper Cover- White - No Sde Markers $125
Rear Bumper Cover - Black - $125
Rear Bumper Cover - Red - $125
Rear Bumper Cover - White - PERFECT SHAPE - $175
Side Skirts- (6 pieces)- black $100
Side Skirts- (6 pieces)- Titanium $100
Side Skirts- (6 pieces)- White $100
Driverside White Door - in excellent shape $100 Each (Pick up only in MN)
<P>
Interior Parts
<P>
Grey Leather Rear Speaker Covers $30 Set
Grey Sun Visor Clips $2 Each
Grey Kick panels $10 Each
Blue Seat Belts $30 Set
Blue Leather rear speaker covers $30 Set
Blue Cloth Speaker Covers $15 Set
Blue Sun Visor Clips $2 Each
Blue Kick panels $10 Each
Black Kick panels $10 Each
All Grey panels Available, Just Ask
All Black panels Available, Just Ask
All Blue Panels Available, Just Ask
Instrument Gauge Cluster $45
ARC Switch $14
Antenna Switch $14
Defrost Switch $10
VMM SOLD OUT
Ash Tray $5
Door Glass SOLD OUT
Window Motor $30
Sunroof Motor $35
Sunroof Glass $25
Coin/cup holders (modified for the MN12) $25
VMM delete panel $7
ABS Computer $30
ARC Computer $30
1990 Auto EEC $35
JBL Stereo Amp $30
jpmcdonald said:Sunny, Id like the '89 T'bird SC rear sway bar. How much to ship to Detroit area ? What shape is the rear bumper cover in ? Thanks,
J.P.
ThePikey said:is the sunroof motor the stock ford one or the ASC sunroof motor??
sunny627 said:Parts List Updated 10/11/2005
Cash Only On Personal Pick Ups.
Thank you,
<P>
DRIVE TRAIN
(1989-1993) 5-speed Tranny w/ 100k works well - $250 (Two available for $400 for the pair)
Body Modifications
(1989-1997) Window Guards - $10 for the set
(1989-1993) Driver-Rear Caliper - $30 Less than 3k
(1989-1995) Front Rotors – less than 3k $15 for the pair
<P>
Power Line (1989-1993)
<P>
DIS Module $35
ABS Relay $20
Fuel Harness $25
Fuel Rail $25
Inlet plenum $30
Stock Air Box $5
Stock Air Tube $5
Oil Cooler $40
Oil Pan $70
Cam Shaft - $65
Crank Shaft - $65
T-stat housing $35
Cam Sensor $25
Crank Sensor $35
Belts $10 Each
Batter Tray $20
Horn $25
Radiator Fan $40
Coil Pack $35
Alt $45
5-Spd flywheel $35
<P>
<P>
Body Parts (1989-1993)
<P>
Hood Latch $25
Header panel $45
Headlights $30 Each
Wiper Arms $5 Set
<P>
Interior Parts (1989-1993)
<P>
ARC Switch $14
Antenna Switch $14
Defrost Switch $10
VMM SOLD OUT
Ash Tray $5
Door Glass SOLD OUT
Window Motor $30
Sunroof Motor $35
Sunroof Glass $25
VMM delete panel $7
ABS Computer $30
ARC Computer $30
1990 Auto EEC $35
JBL Stereo Amp $30
Hello,kpatton said:Do you still have the jbl amp available?
thanks
