Looking for parts-where do you buy from
WickedBird
I'm in need of the following parts and i was just curious where everyone gets theres. The local parts stores don't have everything i need.
Crank Sensor
Cam Sensor
Rear Endlinks-Shortened
Plug Wires-w/ correct factory ends
i go down to the local autozone for all my parts, i know they have for sure the crank sensor, cam sensor, and correct plug wires. not real sure bout the rear endlinks
Anyone have an opinion on what would be a good general length for the shortened endlinks? I wouldn't mind buying them, shortening and then offering them on my webpage.
1-1/2" shorter?
2" shorter?
'bird
It seems everytime I try to get plug wires from autozone, etc they don't have stock wires. I end up with garbage that doesn't fit the coil. I guess I will bug them until i get the correct wires. They were useless in regards to the endlinks also....they can get confused sometimes when it is not the original part you know.
I haven't had the opportunity to check on the sensors, so those shouldn't be a problem then.
