Page 1 of 4 1234 LastLast
Results 1 to 15 of 54
Thread: !~Transmission Coolers~!
    NJ & FL
    1,528
    Anyway. .. The drama continues. .. There's lots of info online already. But here are some finds I've located. ...
    Any opinion's on the following?
    Derale Cooler 30,000 lbs
    Coper Racing Trans Cooler 28,000 Lbs
    Or the one at the bottom of this page
    Advanced Design's Trans Cooler 28,000 lbs
    I've got to stop the bleeding at some point with this car. .. Just cost me over almost a grand from Lentech to get anthoer hardened input shaft & supposedly a stronger drum. ... The stage 1 shaft EXPLODED in there & took out some components with it. .. So, take a look above & let me know your thoughts. .. And some suggestions of your own as well.
    Anthony
    Aug 2004
    Batavia,OH
    2,019
    Here is the perfect cooler.
    I hope you decided to put a 1 piece input shaft in this time.
    I am not a fan of direct drive shafts no matter how expensive they are they are still a long thin shaft.
    Alan
    NJ & FL
    1,528
    If I'm not mistaken, that's what Lentech put in. A Hardened 1-piece input shaft on their Street Term Plus. .... Still Blew It Up! No Clue. .... But, I could be wrong.
    And Damn. .. 40,000lbs ... That does sound like an attraction. I've never heard of the company though... But if it does cool that well, then I'll bet it's what I need.
    Anthony
    Jul 2004
    Salt Lake City, Utah
    1,519
    I'm happy with my 18000 GVW TRU-COOLs. I think that the 40000 GVW model is overkill. It may make the transmission run too cold, is too big to easily install in an SC, and is more expensive.
    Sep 2002
    4,853
    Anthony
    Hows the oil pump on your transmission if it not been replaced it might be the problem not moving the oil it needs to be.
    Just an idea.
    Aug 2002
    Clarksville Tn.
    418
    If you are using a non lockup, and a 3,000 rpm or above stall converter, you can use that 40,000 gvw cooler, and still want more. I have (2) 24,000 B&M coolers, and still see some higher trans temps than I like. In 90 degree heat yesterday on the Hot Rod Power Tour in the hills around Nashville mine got to 210-220 for a longer time than I would of liked. High stall and non-lockup really generates the heat.
    NJ & FL
    1,528
    With a big tube & fin, I'm hitting 210+ after any ride that's more than 30 minutes. Hard or soft. .. Stall is about 2600. .. I know someone else here with a similar setup uses the 2 24000 B&M's as well & it runs well. .. I'm digging the 40k GVW in 1 cooler setup & have plenty of room for it. But I'm wonder whether they really are true to the ratings. If so, then I'm hoping it works out good.
    Anthony
    Jan 2003
    Roswell, Georgia
    594
    Fluid cooler with a fan
    St. Louis, MO
    6,387
    Quote Originally Posted by 392Bird
    I saw similar temps with my Setrab CP 920 cooler, although I never saw anything above 210 and if I dropped to 70 mph, the temp would start dropping. I know, at least in my case, that a little additional ducting to and from the cooler location in my fender would fix the problem. I couldn't find a picture, but you can see one in this PDF. I don't see anything on their site that lists GVW's of their coolers, but I know I've been very happy.
    I'm sure the 40,000 GVW cooler will work well, it just depends on where you mount it.
    Here's a place selling the exact cooler I have, 920FP8. http://www.bakerprecision.com/setrab1.htm
    Kurt K (e-mail)
    SCCoA Member #: 443
    NJ & FL
    1,528
    Well, I've done it. Picked up the 40k GVW .. If this doesn't work, I don't know what will .. But at any rate, I'm also going to take a look at the pump. Could be, but I would hope that isn't the problem. .. Check into that today. Just hope they ship this Cooler soon. Like to be up & @ the track next week.
    Long Tru- Cool LPD Transmission Cooler- 40,000 GVW (4739)
    TRU-COOL LPD LOW PRESSURE DROP OIL COOLERS offer 15 Times Less Flow Restriction and 30% More Cooling. TRU-COOL LPD Outperforms all other coolers. Compared to conventional tube and fin oil coolers, TRU-COOL's LPD patented stacked plate design offers the lowest flow restriction and the greatest heat transfer in the smallest possible package. Self regulating for maximum lube flow protection through cold start-up, varied temperatures and driving conditions, heavy loads and towing. Durable brazed aluminum construction and a lifetime warranty makes TRU-COOL the best choice for any application. This is the same cooler that many OEM's use on new vehicles. (Includes installation kit). Measures 8 1/2x 23x 1 1/4 thick. Perfect for trucks that do heavy hauling.
    Anthony
    20,909
    Quote Originally Posted by SilverCasket
    Anthony
    Anthony,
    If you can find a place to mount it, I think that one will do the job nicely. The stacked plate design is much more efficient than the tube and fin.
    NJ & FL
    1,528
    .. Ok now. ... The cooler's on order. The new stuff is on it's way from Canada. ... .
    Now, when it goes together, I was told that using Synthetic will also make a world of difference in temps? ..
    Anyone have input on Synthetic vs. conventional.
    Anthony
    Sep 2002
    Effingham.IL
    5,011
    I run synthetic in my new lentech.TWO coolers one with a
    fan.Did one burn out at St LOUIS WFC and got thrown out
    of the show.Did two manual shifts with OD locked out ,shifted
    at 4200 RPMs.Babyed this worthless AOD for 1700 miles.Now it slips.
    I pulled out of the shop.It slipped for about 50 feet.worked
    perfect when I parked it.Backed back into the shop.Check
    the fluild level,checked the tv ajustment.check the pressure
    port,everthing was perfect.Fired it back up.And this
    wothless peice off **** shifts and works perfect again.
    Do yourself a favor,pull the AOD and throw the worthless peice
    of**** in the weeds.
    Have I ever told ya, I hate auto trannys with a OD.
    Number 5 coming up.NOT!!!
    RANDY
    Herndon, VA USA
    379
    I just hate autos in general, especially the modern ones. They're getting too cute and fragile. My wife has had transmission troubles twice in her Acura TL-S including a new transmission under warrantee at 28,000 miles. Usually, they're a pain in the ***. The old mechanical Ford C6 I had in my 70 Bird with the full power 429 never got touched in 220,000 miles. I try to go stick whenever I can.
    Jon
    Aug 2004
    Batavia,OH
    2,019
    Quote Originally Posted by Randy N Connie
    RANDY
    OMG man I'm sorry about your luck. If it makes you feel any better I hate these tranny's too. I think I'd rather have a c4
