Results 1 to 6 of 6
Thread: Differences in speedos from 90-94 (pics)
    Mar 2003
    Niagara NY
    2,535
    I picked up a 94 speedo from the J/Y today since it had close to my car's actual miles on the Odometer. When I got it home I noticed that the speedo in my 90 has the numbers in a different position i.e. 60 MPH at 12-o'-clock. The 94's are offset a little .90 on the left, 94 on the right in the pics. Can they be swapped? If they can will the 94 read correctly? almost forgot to mention, The newer one is from a 94 LX tbird.
    Apr 2003
    Arizona
    526
    Near as I can tell, 89-90 have the 60mph straight up and 91-later are like the second one. Notice the starting point of the needle also. I noticed these differences and posted about it a year ago and got no answers then either. IMO, I'm sure they'll swap, but I doubt they will read the same at a given speed. I would be interested in the answer, why don't you try it and post back your results. John
    Mar 2004
    Bay Area, CA
    249
    I've tried the 89-90 and the 91-93. They seem to read the same. But another difference is the 1/10ths on the odometer is set about 1/4 inch to the right on the later gauge.
    Need to be careful if you have a gauge overlays like the indiglo's.
    Mar 2003
    Niagara NY
    2,535
    Quote Originally Posted by minbe
    That's what got me into this mess! I had the white face overlays for a while and i ended up screwing up my stock gauges. so i bought a used cluster and put that in. the only problem with the new cluster is the odometer reads 46,xxx miles more than what is really on the car. i bought the 94 speedo cause i figured in a couple thousand miles i'll be able to slap it in and have the correct miles on the odometer. i still don't know if we can use the 94 speedo or not.
    Madison, Ohio
    17,691
    Quote Originally Posted by NMxr7SC
    Yes you can. There is no difference in calibration, only a difference in orientation of the needle and numbers. FWIW my 90 had the newer style speedo in it. Must have been a mid year change.
    Email me here.
    Mar 2003
    Niagara NY
    2,535
    Quote Originally Posted by XR7 Dave
    Thanks Dave. Now I just have to wait like 6,000 miles before i have to pull over and put the new one in when i get to the right mileage!
  1. New Exhaust..PICS as promissed...
    By fastsc92 in forum Non Technical Forum
    Last Post: 03-18-2005, 08:54 PM
  2. How to Add Pics to Member Page ???
    By SuperCoupe007 in forum Non Technical Forum
    Last Post: 08-05-2004, 11:51 PM
  3. Magna Ported 94 Blower Pics?
    By Conan56 in forum Technical Forum
    Last Post: 06-12-2003, 09:40 PM
  4. Oxygen Sensor differences, and problems. (pics)
    By Bill McNeil in forum Super Coupe Club of Ontario
    Last Post: 06-12-2003, 01:02 AM
