Results 1 to 4 of 4
Thread: runs like crap!
    Apr 2005
    Columbus, Ohio
    5
    runs like crap!
    alright, so haven't driven my cougar since i bought it, but i start it up and let it run every now and then..when i leave it run on its own it will die. when i turn the a/c on it just stalls immediately..any thoughts would appreciated...
    Jul 2004
    Toledo, Ohio
    513
    Iac
    Sounds like the IAC (Idle Air Control) is possibly bad.
    There are a bunch of threads on how to test it.
    Good Luck
    Bill
    Canton (Atlanta area) GA
    1,089
    Check all the SC Intercooler connections for VAC leaks. Reseal everything with (sensor-safe) RTV and see if things improve. If you can pull the fault-codes, that might also help you track down the cause.....
    Apr 2005
    Columbus, Ohio
    5
    ok, update... ran the car for ~30 minutes today.. didn't die once.. when i turned the a/c on the engine would make a clicking sound, go down to about 500 rpm's and then rev back up to 1000. this would happen about every 2 seconds.. with the a/c off it would idle at ~800 rpm's and occasionally go down to 300, start shaking all to hell and then rev back up.. if i got on the gas at all it would do this every time, but if i left it alone it would do it every once in a while.. i tried checking the IAC and from what i read it is fine.
  1. 92 SC for sale LINY (Parts car still runs)
    By The Big D in forum Cars for Sale
    Last Post: 04-11-2005, 09:09 AM
  2. Crap!
    By Sweet90SC in forum Super Coupe Club of Florida
    Last Post: 02-05-2005, 11:01 PM
  3. CRAP! I'm in need of a Multi Function Switch CRAP!
    By Ryan A Harris in forum Super Coupe Club of Ontario
    Last Post: 05-21-2003, 01:21 PM
  4. Bucking SC, then runs Great
    By specialk16 in forum Technical Forum
    Last Post: 04-09-2003, 02:36 PM
  5. New head gskts, Runs like Crap! Help!!!
    By Edman1000 in forum Technical Forum
    Last Post: 02-28-2003, 09:01 PM
