Results 1 to 5 of 5
Thread: SC will not fire -not crank/cam sensors 'I'm pissed'
    Jun 2005
    118
    Sep 2004
    Fort Saskatchewan,Alberta
    105
    codes
    Quote Originally Posted by Lethal-Venom
    Hello everyone,
    I've had my SC for 7 years now
    Parked over 1.5 years
    car died like crank sensor was bad
    Blow HG's 2 weeks later
    Got hg's changed and cracked oil pan bad motor mounts
    Pulled engine changed motor mounts and crank sensor
    Installed everything again
    Will not start but cranks (shift light still on)
    Changed Cam sensor
    cranks but will not fire (shift light still on)
    Fresh gas, oil, water
    everything is pluged in right, neg battery cable goes to drivers side motor mount right?
    OK now I'm lost, pissed get to the end of rope with this car.
    any ideas?
    or do I just tow it to local ford dealership and say 'fix it'
    Thanks for your help
    'Lethal-venom' or Chuck
    have you checked for error codes? that's the first place to look .
    Jun 2005
    118
    Lakeville, MN
    13,517
    If the upshift light is on during cranking then the EEC-IV is not receiving the signal from the Crank sensor. Regardless of if you changed it out or not, the system isn't getting the signal. This could be due to a wiring issue rather than a sensor problem.
    When you installed the harmonic balancer and Crank Sensor, how did you adjust the position of the crank sensor? Standard adjustment is stick a matchbook cover between the sensor and the slotted wheel and then tighten the sensor down. Did you do that?
    Jun 2005
    118
  1. Replies: 1
    Last Post: 12-06-2004, 12:23 AM
  2. Car fire on halloween-burnt shell remains
    By Charkly in forum Non Technical Forum
    Last Post: 11-04-2004, 11:56 AM
  3. Fire In The Hole!!!!!!!!!!!!!
    Last Post: 08-23-2003, 05:47 PM
  4. Engine on Fire Tonight, Please help?
    By NOTYSC in forum New SC Owner Forum
    Last Post: 10-26-2002, 04:26 AM
