Results 1 to 15 of 28
Thread: 94 SC PARTS FOR SALE (Some 5spd items left)
    Oct 2004
    Baltimore, MD
    252
    Exclamation 94 SC PARTS FOR SALE (Some 5spd items left)
    SC PARTS:
    $150.00 for front bumper cover (is flawless)
    $200.00 for complete dash assy. less A/C controller (includes complete dash wiring)
    $50.00 for hood (less hinges)
    $200.00 for custom trunk lid (body work has been done to shave trunk lock and "ford" emblem. Ready for paint) email for pics.
    $50.00 per side front spindles (includes rotor, caliper, hub, spring, firm ride strut, and upper and lower arms) - NO HARDWARE
    $35.00 for strut tower nuts and bolts (All four, 2 per side)- NLA from FORD
    $40.00 gas tank. Includes pump and sending unit
    $175.00 per comlete door with shaved door handles and hinges (less mirrors and interior trim panel). Includes int. handles and glass w. regulators. No solonoids or actuator motors are included with shaved handles, this is an SC door.
    $120.00 front wiring harness w/ 53 pin connector (includes under hood fuse box)
    $70.00 5 speed drive shaft
    $25.00 for 5 speed trans block off plate (bolts to bell housing
    $45.00 MAF sensor
    $200.00 for complete power moon roof with glass, seals, motor, wiring, and switches. Will supply whole roof for same price if you want to add moonroof to your non-moonroof car if local pickup
    $40.00 firm ride controler computer
    $75.00 for moon roof headliner
    $35.00 for sway bar, brackets, and factory end links
    $50.00 for manual trans radiator
    $40.00 for A/C lines
    $20.00 per side power mirror with wiring
    $10.00 ea. for factory corner lamp housings
    $35.00 for set of 4 LX tail lights (L.E.D. panels partially out on left side)
    $25.00 for all seatbelts (gray)
    $150.00 for set of 16" SC wheels, includes tires with partial tread and center caps. Wheels need to be refinished
    $50.00 rear windshield with defroster (if can be removed with out cracking)
    $25.00 for SC ignition box
    $25.00 radiator cooling fan
    $40.00 (set, all four) for firm ride shock sensors and pigtails
    $50.00 steering rack
    $30.00 power steering pump complete
    $20.00 for alt. and pulley
    $35.00 for 1995 LX air bag
    $50.00 for pass side 1.5" axle
    $50.00 front subframe/ crossmember
    $45.00 for accessory brackets and idler pullies
    $20.00 used clutch
    $50.00 5 speed flywheel
    Last edited by Mercury267; 07-11-2005 at 12:48 AM. Reason: Some of the parts on this list have been sold...
    Aug 2002
    94
    do you by chance have the right rear halfshaft? I broke mine on my 95 sc 5-speed the fat one...do you have one? Let me know
    Chamelionsc@aol.com
    Oct 2004
    Baltimore, MD
    252
    I have that half shaft.
    Jun 2005
    Dallas
    5
    Cooling Fan
    Is that cooling fan the small push fan or the bigger shroud and fan assembly? and is it original or a replacement?
    Aug 2002
    3,660
    No chance of getting #36 injectors?
    Jun 2005
    1
    Cool Dibs On The Clutch Pedal Assembly
    I NEED THE CLUTCH PEDAL ASSEMBLY WITH THE LINES AND RESERVOIR. HOW MUCH ON THESE PARTS PLEASE?
    Quote Originally Posted by Mercury267
    SC PARTS:
    $50.00 for CUSTOM fender SHAVED ANTENNA WHOLE (right side)
    $45.00 MAF sensor
    $20.00 used clutch
    Apr 2005
    Indiana
    21
    Thumbs up sc parts
    $45.00 MAF sensor
    $20.00 used clutch
    $50.00 5 speed flywheel[/QUOTE]
    do you have all of the side skirts and rear bumper how much shipped to 46041 can also reach me at clancyswheels03@sbcglobal.net thanks
    Oct 2004
    Baltimore, MD
    252
    Guys ... the parts which are listed are all i have left.
    The injectors were the first items sold, then the blower, intake, and the rest of the motor was picked up last weekend.
    The 5 speed items listed are all that are left ... no pedals, no console, no e-brake, no lines, harness, shifter, trans., or master ... it is all gone.
    I posted the list so that I could keep track of the items left.
    The radiator is the large "puller" fan, not the pusher fan on the front of the radiator. I believe the fan is a ford fan, but I couldn't tell you if it is the original. I know it runs with out any bearing noise coming from it.
    The only items not on the list are the rear upper and lower arms and the knuckles. Those can be purchased if needed, but other than that everything else that is left is listed.
    Thank you guys... I appreciate you taking a peek at the post and asking about additional items.
    Tejas...home of Stevie Ray Vaughan
    1,748
    How 'bout the EEC?
    'bird
    Oct 2004
    Baltimore, MD
    252
    Just sold the EEC to Rick from MN12 performance ... nice guy, it was a pleasure to deal with him. I hope to see his car sometime soon.
    Jun 2004
    Lehigh Acres FL.
    195
    do you have the crank shaft encoder wheel that is mounted to the back of the harmonic balancer. it look like a gear that has 36 teeth but is missing one tooth. if you have that you can pm me with how much you want for it. i need it asap. thank you.
    Billy
    Oct 2004
    Baltimore, MD
    252
    Sorry ... that item was sold with the engine last weekend.
    Thank you though.
    Ozzman is parting out his 95 SC ... you may want to hit him up for that one.
    Brantford, Ontario, Canada
    4,004
    I'm looking at your front bumper, can you PM me a quote to ship Canada. Postal code(same as ZIP) L7G 6K3. Thanks alot.
    Jun 2003
    Lawrence Kansas
    65
    My '95 SC needs lots of parts! (cheap!!)
    Have you got anything left? Thanks Donnie189@yahoo.com
    SC PARTS:
    $45.00 MAF sensor
    $20.00 used clutch
    Oct 2004
    Baltimore, MD
    252
    Pretty much everything o nthe list is still avail., but I am selling and shipping out items about every 3 days (give or take). I just shipped the pass fender tonight and removed that item from the list.
    The wheels are going next.
    I ONLY have those items shown on the list left. Anything else has either been sold, or is not for sale so I can use it on my car.
    If you would like to make arrangements for something, email me directly at mercury267@juno.com
    Thanks,
    ~Mercy
  1. Spare SuperCoupe Parts For Sale
    By SeanMatteson in forum Super Coupe Club of Ontario
    Last Post: 04-22-2012, 10:48 AM
  2. SC & MN12 Parts - Large Inventory
    By racecougar in forum Parts for Sale
    Last Post: 02-14-2011, 09:33 PM
  3. Need some special parts
    By victor malvar in forum Want to Buy
    Last Post: 05-10-2005, 05:43 PM
  4. Who needs miscellaneous parts??? I need the space in my garage!!!
    Last Post: 10-24-2002, 06:43 PM
  5. XR7 left in the sun.....need interior parts now.
    By 01GTCOUPE in forum Technical Forum
    Last Post: 08-07-2002, 11:50 PM
