Results 1 to 7 of 7
Thread: 5% pulley with stock HG's
    Jul 2004
    Outskirts of Richmond Virginia
    100
    145K miles, with stock, 1993 factory head gaskets. According SCP, a 5% pulley wont harm the HG's... but I'm not sure. Anyone else run this combo?
    Also using a stock Jackshaft (these things are like $300?!)
    I'm assuiming I would need a new belt too, huh?
    Its a COMPLETLY stock engine, (except removed silencer) with 5-speed.
    Aug 2002
    443
    Well, a removed silencer is not gonna be enough to save your headgaskets if you do go with a 5 percent SC pulley. You should at least do exhaust. If you do not, you are really at risk of blowing your HG's! I had a full exhaust done, no cats, and stainless steel magnaflows (2 mufflers and resonator) put on for 600 bucks, way cheaper than new HG's. I would at least get rid of, or get better flowing cats before you mess with the pulley.
    I'm sure much more knowledgeable people than I will chime in soon to tell you the same.
    Good luck!
    Sep 2002
    Ensenada B.C. Mexico
    1,223
    i removed my cats and intalled a magnaflow resonator when i installed my 5% pulley, and my head gaskets lasted like a year or more , but they blew because my radiator cap was failing.
    20,970
    Quote Originally Posted by TealThunder
    The head gaskets are going to fail no matter what you do, IMO another 5% of overdrive isn't going to have much impact on how long they last. Stock belt is fine for 5%.
    Madison, Ohio
    17,586
    What David said. Your headgaskets are already shot. How fast do you want to do them in? Temperature is the #1 factor followed by detonation and lean AF mixtures. Exhaust back pressure is not your primary concern.
    Email me here.
    Philly
    2,427
    Quote Originally Posted by David Neibert
    I agree with David. I blew my head gaskets @ 92k with stock blower pulley and headers and 2.5" dual exhaust. I ran this set up for about 30k, so take it for what it is worth.
    Good Luck
    1992 Thunderbird SC
    13.322 @ 102.81
    1993 Thunderbird SC 5spd..white
    2002 F350 SD Diesel (SC tow vehicle)
    Feb 2005
    Chandler, AZ
    228
    just make sure to do the exhaust. i took too long to get my exhaust done after i put on my 5%. my head gaskets are fine (well they blew for a different reason), but i blew an exhaust gasket because of the pulley. exhaust then pulley.
  1. stock pre-94 blower pulley
    By matt'sdrag95 in forum Want to Buy
    Last Post: 02-18-2005, 05:38 PM
  2. Problem sovled?!?!?!?! MAybe
    By Lugen in forum Technical Forum
    Last Post: 04-02-2003, 08:04 PM
  3. Level of interest: Balanced Aluminum Crank Pulley Stock Size
    By white91sc in forum Non Technical Forum
    Last Post: 05-07-2002, 02:20 AM
