Results 1 to 7 of 7
Thread: 90 Engine wiring harness
    474
    I have a 90sc aod without ERG valve. The old motor was not in the car when I got it. The engine I have now, is from a 90 sc 5speed with EGR valve.
    My question is can I use the engine wiring harness that has an EGR valve hook up. And another thing is this connector, there even if you don't have an EGR valve. This is a little grey connector. Reason I ask this is because I picked up a wiring harness off a local member and hes 100% sure its off a 91sc aod without EGR valve. It has that grey connector for the EGR valve.
    474
    Well seems like nobody can help out on this one.
    So maybe somebody has a spare or torn down engine. If you do and its a 89-91 aod without EGR valve. Then can you please check your engine wiring harness at the back of the engine, in the middle for that grey connector. It is connected with the fuel injector wiring harness.
    Heres a pic.
    Oct 2004
    Lake County, Florida
    870
    I have taken EGR Valves and DPFE senosrs out of 89 and 90 cars, but not put them back in. That plug is for the DPFE sensor which has a vac line to EGR Valve.
    474
    Quote Originally Posted by unclenick
    My EEC is factory set as a 90 aod without EGR valve, and my new motor did have an EGR valve and that DPFE you are writing about.
    When you removed your EGR valve and DPFE. Didn't you need an EEC tuner?
    Nov 2004
    Brantford, ON
    5,383
    I have a '90 AOD, and yes the harness has the connector for the EGR but I don't have EGR. I'm assuming the EEC itself has been set up to not look for the EGR valve. On my intake plenum, there is a plate that covers where the EGR valve would go.
    I would think using the harness you have is not an issue so long as you use your original EEC.
    Frit
    Southern California
    303
    Shawn
    Here is a thread with some more info that might help. I posted a picture of the rear of a 90 engine. Look at message #7.
    http://www.sccoa.com/forums/showthre...gray+connector
    Take Care
    To ALL my fellow Veterans........Thanks!!! U.S. Navy (Corpsman) 1967 - 1971.
    1990 SC
    1997 Mark VIII LSC
    1998 F150 Lariat
    474
    Great thanks alot guys for the help.
  2. JBL Wiring harness and wiper shielding
    By Dhansing in forum Want to Buy
    Last Post: 11-13-2004, 12:25 PM
  3. Wiring harness for 94 5spd
    By 94scoupe in forum Want to Buy
    Last Post: 09-27-2004, 02:00 PM
  4. engine comp. wiring
    By tow_this in forum Technical Forum
    Last Post: 09-20-2004, 05:18 PM
  5. Wiring HArness Connecter Qestion
    By Lugen in forum Technical Forum
    Last Post: 03-16-2003, 01:55 AM
