Thread: Non functional ARC
    Feb 2004
    Gillette, WY
    Non functional ARC
    Ok guys, I took the arc cover off the driver side, (three clicks/three blinks), took the actuator off, gave her a shot of WD-40, spun the pin. Put the thing all back together, and the firm ride light still blinks three times. What would be the best route to go. Get a new actuator, or are the shocks wasted? Thanks for all the help, Art
    Nov 2002
    Middle-O-Nowhere, Upstate NY
    well-with the actuator off, have someone sit in the car and hit the switch while you watch the actuator and see if it rotates 90 degress-if it doesnt, its the actuator. If it does, then the shock/strut is bad-simple system really. Mike
    btw-if you need an actuator or shock, if you can wait a couple weeks until i get to my home in ny-ill send you either for the cost of shipping. Mike
    Dallas, TX
    Actually, its more like 30 degrees of rotation.
  1. Gutting the ARC?
    By dklitzke in forum Technical Forum
    Last Post: 02-14-2010, 03:27 PM
  2. ARC Module
    By HoseHead in forum Super Coupe Club of Ontario
    Last Post: 10-04-2004, 02:08 PM
  3. ARC stuck on!
    By canadabird in forum Technical Forum
    Last Post: 02-16-2004, 06:30 PM
  4. ARC stuck on!!
    Last Post: 02-15-2004, 08:42 PM
  5. New Polyurethane ARC Shock Mount Kits...
    By Rich Thomson in forum Technical Forum
    Last Post: 06-23-2003, 09:14 PM
