View Poll Results: What Compound are you using on the bottom of you DIS
Voters
113. You may not vote on this poll
  • Silicon Dielectric Grease
    36 31.86%
  • Heat Sink Compound
    62 54.87%
  • Petroleum Jelly
    2 1.77%
  • Super Glue
    6 5.31%
  • Other
    7 6.19%
Results 16 to 23 of 23
Thread: What Compound are ou using on your DIS Module
    Lakeville, MN
    13,517
    picked up white heat sink stuff from Radio shack. Works o.k.
    Aug 2004
    2,025
    Dielectric grease is a non-conductive grease. Because it is non-conductive it does not enhance the flow electrical current. Electrical conductors should not be coated with dielectric grease prior to being mated. However, dielectric grease is often applied to electrical connectors, particularly ones which contain rubber gaskets, as a way to provide a non-conductive lubricant and sealer for the rubber portions of the connector.
    The widest use of dielectric grease is in high-voltage connections associated with spark plugs. The grease is applied to the rubber boot of the plug wire. This helps the rubber boot slide onto the ceramic insulator of the plug. The grease also acts to seal the rubber boot, while at the same time preventing the rubber from becoming stuck to the ceramic. Generally spark plugs are in located in areas of high temperature, and the grease is formulated to withstand the temperature range expected.
    Another common use of dielectric grease is on the rubber mating surfaces or gaskets of multi-pin electrical connectors used in automotive and marine engines. The grease again acts as a lubricant and a sealant on the non-conductive mating surfaces of the connector. It is not recommended to be applied to the actual electrical conductive contacts of the connector.
    Aug 2004
    Batavia,OH
    2,019
    I have seen a guy put dielectric grease on one after I specifically told him heat sink compound and then the car would not start. I looked into my computer stuff found a pack of heat sink compound and wiped the grease off and redid it. It ran just fine after that.
    Alan
    Jun 2009
    101
    I use something similar to this...
    http://solutions.3m.com/wps/portal/3....tsrc=Redirect
    It's not made by 3M, and can't for the life of me remember who it's made by, but we use it here @ work for thermal transfer in a vacuum chamber. Completely insulates electrically, but had no problem w/ car starting or running. It even fixed the car stalling in the parking lot here at work and just seems like the idle is stronger too...
    6,537
    Quote Originally Posted by TvilleTbird View Post
    The pedestal is hotter (which is one reason why the DIS was moved off it in later models) - why would you add anything that aids heat transfer upwards into the DIS...
    Aug 2004
    2,025
    I had a 90 and I still have a 95. DIS were a lot more troublesome on the 90 for sure but, if you did the correct setup with the correct compound, the problems were minimal.
    6,537
    Quote Originally Posted by rickbtbird View Post
    I think some of the newer DISs for the early cars help overall.
    Nov 2010
    7
    Cool
    I use anti seize compound. Works great.......
  1. New and need help
    By Garrard8 in forum Technical Forum
    Last Post: 01-31-2005, 01:43 AM
  2. DIS Module Bad Again?
    By Charles G in forum Technical Forum
    Last Post: 12-26-2004, 12:39 PM
  3. dis module
    By sho taurus in forum Technical Forum
    Last Post: 03-20-2004, 10:16 PM
  4. can bad cam sensor damage DIS module?
    By kevenj90sc in forum Technical Forum
    Last Post: 04-01-2003, 06:27 PM
