Results 1 to 9 of 9
Thread: No blown head gaskets with this engine
    Allentown, PA
    733
    This is an interesting design by SAAB. The heads and cylinders are cast as one piece so there are no head gaskets at all.
    They vary the compression by tilting the entire upper assembly.
    http://72.14.207.104/search?q=cache:...monohead&hl=en
    Jul 2004
    Toledo, Ohio
    513
    Interesting....hmm!
    That is one really neat design concept. And I would have to agree that it could eliminate headgaskets.
    The only issues I see with it is the complexity.
    Plus if you ever HAD to replace the head, oh baby $$$$$$$.
    Still a neat idea.
    Bill
    Allentown, PA
    733
    As I see it, you don't need to have the variable compression aspect of the design it if you don't want it.
    You could do the same thing for a fixed compression setup thereby eliminating the complexity.
    Feb 2004
    St. Louis, MO
    155
    anyone remember the ford 'flathead' engines... the head was cast with the block hence no head gasket. all one piece
    7,569
    Flathead Ford V8s had cylinder heads, they were just flat casting though ... the valves were in the block, not the heads.
    cheers
    Ed N.
    Jan 2005
    Longwood, Fl
    206
    1 pc block/heads
    Mercury outboards had a 1 pc block/head design. Dont know about other brands or even present outboards, but older versions did. Bolts that looked like head bolts were only to remove the water jacket cover over the heads. Sparkplugs stuck through a hole in the cover.
    YB
    H-Town Tejas
    2,891
    Quote Originally Posted by yardbird
    YB
    That's a 2 stroke though so it's not the same.
    If you have a 1 peice design then it adds complexity and expense to the parts and makes it really hard to modify. Haven't looked at the article but remember one in a Design fax I got about 6-7 years ago.
    Jeff
    Jan 2005
    Longwood, Fl
    206
    2 stroke
    Of course its a 2 stroke--------!
    Simply pointing out that there are engine designs with one-piece block/heads. I dont see how valve/seats could be done in a one piece design though.
    YB
    Feb 2003
    Wichita, KS
    1,653
    who cares about the headgaskets, that is an awesome concept for efficiency.
  1. Who has blown head gaskets using Fel-Pros?
    By Bill A McNeil in forum Polls Forum
    Last Post: 06-16-2015, 11:32 AM
  2. My head gasket how-to
    Last Post: 05-15-2009, 01:18 AM
  3. whats the best head gaskets, motormounts, etc
    By cougar20th in forum Technical Forum
    Last Post: 12-17-2004, 05:20 PM
  4. 91 SC Head Gaskets
    By tbirdmarc in forum Technical Forum
    Last Post: 09-18-2004, 10:18 PM
  5. Head Gasket & Engine Work Help Needed... BADLY!!
    By SnoopyLuke in forum Super Coupe Club of Ontario
    Last Post: 04-26-2002, 01:21 AM
